bigrich954rr
Bronze Member
- Joined
- Sep 27, 2016
- Messages
- 87
- Location
- oregon
- Tractor
- branson 4720h 6ft brush hog ,post hole digger, ripper, pallet forks,
Towards the right side almost directly under the loader Control joystick on the bottom of the tractor is a hydraulic filter just forward of the hydraulic filter is a line going to the front of the engine with a small rubber hose that connects two metal lines with two hose clamps one of the hose clamps broke which caused a slow leak.
I started looking over the tractor because it had a shutter whenever using a hydraulic components.
I didn稚 find it until I got back to the shop which means I drove through a bunch of muddy fields and water holes.
Think the shutter was sucking air ?
If sucking air most likely sucked in a little water ?
Guessing time to drain and refill ? Am I missing. Anything else ?
