Center support beam?
   / Center support beam? #1
kojo
galivants ferry,sc
1954 john deere 40
How's it going ya'll, I'm fixing to start building a 40'x20' open pole barn and was wondering about a couple of things. 1st off, I haven't checked all the lumber yards, actually all but 2 i have checked, and can't find anything longer than 16'. If I can't get 20' long boards, I was gonna get 12' long and lap them together for the joist. I'm making it a sloped flat roof. If I lap them together, do I need a center support beam? Next question, If I were to luck up and get 20' long 2x8, would I need a center support beam or could I step up to 2x10 and not worry about the center support beam(providing I can get'em)? I'm going with a metal roof, so there won't be that much weight on it. I was also wanting to go 24" centers. I appreciate any help and advice ya'll can give me on this. Thanks.
   / Center support beam? #2
Do not try to lap together your boards.
You can get boards up to 24 ft long at most lumber yards. I go to McCoys to get mine. According to the span tables I just looked up, it is possible to get get 10 and 20 psf ratings with certain 2x10's and 2x12's. You need to know what type of wood you are buying and then do a search under span tables to figure out your distance and spacing.
Does it snow where are located?
Why not just buy or build trusses?
Eddie
   / Center support beam? #3
What about a steel I-beam, KOJO?
My workshop building uses one that is 30ft long and about 12" in depth. You will find
that they are less costly and lighter than equivalent-strength wood members, including
engineered lumber.
You can also attach wood nailers to the top or bottom flanges with a Ramset-type
PAT, if you keep the flange thickness below a quarter inch.
A ridge beam will give you the head space for a ceiling hoist and trolley. I love mine.
   / Center support beam? #5
I vote trusses too. Look around, sometimes people order floor trusses and they end up wrong. You may find some a yard needs to get rid of. You might have to adjust your dimensions a little bit if you get a deal on some but that's part of saving money.
Thanks for the replies guys, I don't have to worry about snow here, the most we'll get is 2-3", last winter we didn't get any. Boards are gonna be treated southern pine. As for the trusses, I'm gonna be mainly doing this by myself so I figured the sloped flat roof would be easier on me than the trusses would be. And I don't know much about the steel beams. I was hoping I might be able to find 20' long boards and also hoping I wouldn't need a center support beam. I'm gonna call a couple more places tomorrow and see if they have them. There's not gonna be too much weight on her accept the metal or tin roofing. I hate to go the lapping route, because they would definitely need some center support. Thanks again guys.
   / Center support beam? #7
You want yo make it easier on yourself? Buy trusses.
   / Center support beam? #8
Have you considered using I joists? For solo construction the're great. Light and EZ to cut and handle.
A yard caring TJI joists will usually have a computer program to take all the guess work out of span depth and joist spacing.
   / Center support beam? #10
I'm not a builder, but why treated? They are extremely heavy and not necessary for roofing members.
Agreed, and if using a metal roof it adds all sorts of issues, from requiring hot-dipped galvanized roofing screws to needing a barrier between purlins and metal. I had to use pressure treated wood for a pier boathouse roof due to the wet location, and it was a pain. If you're on land then by all means you should use standard lumber.
   / Center support beam? #11
You said joists. Are you putting a 2nd story floor in or did you mean roof rafters?
Do you have a sketch of what you want it to look like when you're done?
If not then do a sketch and take it to a lumber yard to get some advice. Sometimes a back and forth discussion in person can get you squared away faster.
   / Center support beam? #12
I may have used the wrong wording. I said "trusses" but I meant floor joists too. You know, the ones that you can lay from one basement wall to the other without having to use metal poles in your basement.
I have seen them made with wood on the top and the bottom with OSB in the middle, they look like wooden I beams. I think they make them out of different stuff and call them "LVL's" or something like that. I believe you can also get them with a 2x4 on the top and the bottom, with 2x4 cross bracing inbetween. These are all very long, very strong engineered joists and would work perfect for a slanted flat roof. I bet you can get them up to 30ft long, maybe longer.
   / Center support beam? #13
Here's the ones with the OSB in the middle.
   / Center support beam? #14
Here's the ones with the "X" bracing in the middle.
GP, I guess I meant rafters, there's not gonna be any weight on the top except for the metal or tin roofing. But, I did find some 20' long 2x10's, I finally found a place that has them longer than 16', which is great because now with those, I shouldn't need a center support brace, I hope. I have drawn up a blueprint myself to kinda go by.
franklin, I like the looks of the LVL's but, I haven't priced them, I was trying to keep the price as low as possible and I figured they were probably pricey.
   / Center support beam? #17
Check the rafter tables for 2x 10 s to see what they will support on a 20 foot span. Figure your deadload and any snowload for your area if any . Then you can figure the spacing needed.
   / Center support beam? #18
Use the manufactured joist as shown in franklin2's first pic. They are stronger, straighter, and lighter to handle. They won't warp or twist and they can be made any length you want. ( the ones with OSB in the center--like an I beam)
No center beam required.
   / Center support beam? #19
Most places like Menards can order up to 24' lumber for you. I joists are lighter , truss types are lighter too than big deep beams .. If you were meaning beams to support the entire roof , a good steel shop could give you the size required for the span .. 6" beam or two pieces of 6" c channel drilled and bolted is shorter than a similar strength wood beam
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
John Deere 5045E for sale Auction
John Deere 5045E...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
