the problem I see with the three point frames, is that you just can't get the terrain following agression applied by simply dragging it behind a tow bar. It's going to skip, drag, and bounce as the front wheels of the tractor rise and fall with the terrain. When dragging it with a chain and a tow bar, it never leaves the ground - till you lift it with something like I had built.
The frame is nothing more than USED inch and a quarter steel pipe. Old rebar was bent into U shapes, and welded to the inside of the frame and cross member for harrow attachment points. Galvanized quick links were used to attach the harrow sections to the rebar connecting points. Rebar was also bent and welded to make chain attachment points for more quick links. That's all there is to the frame.
The boom pole is standard duty Cat 1, $79 at a farm supply store. An 18 inch piece of square tubing was slid inside the end, and welded in place. A five foot section of square tubing - the same size as the boom pole - slides over the end section. It's held in place with a PTO pin. Two chain keys were welded on. that's all there is to the boom pole.
So the material's readily available, and reasonably priced. All you have to do is find a welder to put it all together.
Balance is the key. I experimented with wood frames initially, just so I could find the best chain arrangments and attachment points. That way, the welder had a plan to work from - instead of trial and error to get it to hang right. I can send you some measurements by email, if you'd like.
//greg//
