Chain saw / hedge trimmer hybrid.
   / Chain saw / hedge trimmer hybrid. #1
Reg
Elite Member
What the title says.
Hedge trimmers "aren't big enough" for a lot of heavy overgrowth, brush, etc.
Chain saws grab and whip it.
What I am wish-dreaming for is something like a hedge trimmer set of fingers that bolts onto a chainsaw bar.
It would catch the thick springy stuff and stop it from whipping while the chain cuts it.
Does this exist ? For a good/fair price ?
{cc my patent attorney, just in case this doesn't exist (yet) - this is the original art}
   / Chain saw / hedge trimmer hybrid. #6
Looks like you have to drill the bar to mount it.
My neighbor was building a chainsaw based sawmill and couldn't drill a half inch hole thru his Huskavarna(sp) bar with a hand held drill. We did it in my mill and that steel was pretty tough. I did use a Chinese drill rather than one of my good ones but you could still tell. Maybe the consumer grade bars are easier to drill?
   / Chain saw / hedge trimmer hybrid. #7
Depends on the bar.. many already have a hole towards the tip that can be used, and the rear is held on by the 2 bar bolts.
http://www.chainsawsdirect.com/product-images/FT280-72_10282_225.jpg
A good example being my 28 inch Husky bar, it has an "almost hole", i.e. punch out the little disk to create a hole.
Some people may try to drill this out, I wouldn't :D
Bahh, now I'm obsessing over a Granberg Alaskan mill - my xp390 is 88cc., so that could drive a 36 inch mill with no sweat.
Then there is the 2100 that hasn't been run in years, maybe I'll resurrect that to go on the other end :D
   / Chain saw / hedge trimmer hybrid. #9
I have the Granberg Clip-N-Trim (Chainsaw Brush Attachments | Granberg International), and have used it on a few occasions. It works for hedge/brush trimming, but the finish will not be quite as clean as a true hedge trimmer. On the other hand it will cut any limb/branch that will fit between the "fingers".
It doesn't require any drilling or modification of the bar or chain.
   / Chain saw / hedge trimmer hybrid. #10
Have you thought about a string trimmer? I know several brands offer a hedge trimmer attachment for them. I borrow a friends Sthil for the rare chances when I need one. Anything that doesn't fit between the teeth I use my trimmer with the saw blade attached.
2012 Nissan Altima Sedan (A55758)
2012 Nissan Altima...
Mercury 60hp Boat Motor (A54865)
Mercury 60hp Boat...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
UNUSED AGT STSD10 Seeder (A47477)
UNUSED AGT STSD10...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
