Chainsaw Bar Length?
/ Chainsaw Bar Length? #41
Last weekend the trees started to leaf out and I noticed two more dead trees that need to be cut down. No reason they should have died, the largest one is not even 6 inches in diameter and not very tall. I can only guess that lightning hit the trees even though they are shorter than surrounding trees. :confused3:
Later,
Dan
If they were shorter then the surrounding trees then they may have just lost the race for sunlight.
/ Chainsaw Bar Length? #43
You need to saws so when your neighbor shows up you can put him to work
/ Chainsaw Bar Length? #44
You don't need two saws.
I hope my wife never reads this. Although I was up to 7 saws at one point, I have now reduced the herd to 3 :D
Sometimes it ain't about need, sometimes it's about want. :laughing:
/ Chainsaw Bar Length? #45
I've been told a man just can't own too many chainsaws.
/ Chainsaw Bar Length? #46
In my experience, which isn't much, is that a minimum of two saws are required. The smaller one for the last half of the day, and to cut the larger one out when you pinch the bar.
/ Chainsaw Bar Length? #47
Axe works too!:D
Years ago I was working on a clear-cut of a burnover. I was the only one who had cutting rights there.
Rolled in one day and found a tree down that shouldn't have been. Also found a "beavered out" notch obviously done with an axe where the perp had chopped his saw free.
He had made away with one small tree (leaving all the mess for me to clean up) apparently before sticking his saw.
Harry K
/ Chainsaw Bar Length? #48
That is a good thought and much better than a lightning strike. :eek: We have lost quite a few trees to lightning so that was my first thought but loss of light could be it. Flip side is that the trees would get a fair amount of light from the east and west and very little from the south...
Later,
Dan
/ Chainsaw Bar Length? #49
Not trying to hijack the thread, but what dmccarty says about trees dying with no apparent cause reminds me of the sugar maple in my side yard, it was about 25 years old and 16" across at the base when cut down, about 8 years ago I noticed many of the limbs were dying for no apparent reason, the limb dieback got progressively worse until close to two thirds of the tree was dead. when I cut it down two years ago I found no hollowing of the trunk and no sign of disease. The only reason I could think it might have died is because back in 2002 and 2003, we hired an excavating contractor to come in and dig a new foundation hole, although the hole was at least 25' from the tree trunk, a LOT of heavy dump truck and front end loader traffic crossed dozens of times over at least a third of the roots and I suspect soil compression was the reason for the dieback.
/ Chainsaw Bar Length? #50
Later,
Dan
I expect that it is the total light received in a summer that determines if enough photosynthesis can occur for the tree to turn a profit. Saplings growing up in a cut or blow down clearing in a forest have to grow really fast and straight to beat out the competition as only the one to reach the canopy height first will win out and all the other contestants will wither and die. Survival of the fittest don't you know.
/ Chainsaw Bar Length? #51
An extra four inches of fill if sterile soil can smother the roots and is all that is needed to kill a tree no matter how large. Add in some road salt to the fill and even less will do it. I don't know if root compression can also do it but most cases of traffic applying root compression also involve the importation of some contaminants or over fill.
/ Chainsaw Bar Length? #52
There may have been some disease in the area. Might want to check with extension service. In Ohio we ate suffering fom the emerald ash bore. This is killing off ash trees in about 4 years. The Dutch Elm disease killed about 200 million trees. This bug is going to kill over a billion trees. You do not realize how common ash trees are until you see a area where this has happened.
/ Chainsaw Bar Length? #53
I'm trying to market mine now while I can. Talked to a cabinet maker just yesterday that wants a couple of eight foot logs of clear number one. Wish he needed more. I'll sell all the small stuff as cord wood this year and next and ship the saw logs as I can get the mills to take them.
/ Chainsaw Bar Length? #54
Doggone invasive pest species are wrecking the landscape. Dutch elm fungus, oak wilt fungus, emerald ash borer, gypsy moth, etc. etc.
Pretty soon there won't be any nice hardwoods left. Dutch elm wiped out the elms here, oak wilt has taken many of the hard oaks (black & red), gypsy moth outbreaks have wiped out some nice forests, now here comes the emerald ash borer. Everybody planted ash trees as the 'safe' replacement for the others. Hah!
Anyway, I'm about done with hard oak removal & processing after 22 years. But that's why I needed 3 pro quality saws. The tree service guys wanted about $1000 a tree and I had 70 of them. I burned most of them for heat, but I wish I had access to a mini sawmill. The red oaks would have made gorgeous furniture.
Oh well.
/ Chainsaw Bar Length? #56
To be clear.... the axe never works.:laughing:
I don't know what you are talking about. A good sharp axe is what they used to cut down all the old growth timber east of the Mississippi. The two man crosscut saw came in late but modern chainsaws didn't come into common use until after WW2. Slow of course but it will get the job done if you have the time and know how to sharpen it.
INOP/NON-RUNNING 2012 Jaguar XJ Passenger Car, VIN # SAJWA2GE5CMV37496 (A61165)
INOP/NON-RUNNING...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
2016 Kubota L3301 (A62177)
2016 Kubota L3301...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2015 TAKEUCHI TB240 EXCAVATOR (A62129)
2015 TAKEUCHI...
207278 (A52708)
207278 (A52708)
