Chance to buy a disc harrow, help please
   / Chance to buy a disc harrow, help please #1
Laminarman
Upstate NY
TC40DA
I have the opportunity to purchase one of two disc harrows. These will be for food plots and a little light farming (up to 8 acres max of maintained planting). I have a gift certificate for $100 to TSC and see their angle frame harrows for under $600. But my dealer has a normally $1500 heavy duty disc harrow (Land Pride) sitting on the lot (brand new) and he'll give it to me for a little under $1,000. The Land Pride is a big step up in quality and weight. Question is, do I spend more (which I don't want to) and get a lot more, or will the angle frame harrow do the job okay. The TSC weighs in at around 560lbs while the Land Pride I think is a little under 900 lbs. I don't want to buy another one of these for a long time. Both are the 6' models. You can see the quandary is putting out about $500 cash at TSC versus twice that much at the dealership. I don't mind spending the money if the Land Pride is that much better and longer lasting than the King Kutter.
   / Chance to buy a disc harrow, help please #2
For my money I'd spend the $1500. I think those cheaper ones are just too light to do the job alot of the time. They work ok after you have already worked up the ground with a plow or chisel plow. But if you're trying to work ground that hasn't been worked any then you will appreciate the extra weight.
   / Chance to buy a disc harrow, help please #3
Get the Landpride. I got the same Landpride disc and have been very happy with it. I used to wonder about saving a few dollars when making such purchases, not any longer. I buy the better quality product even if it takes me a littler longer to save the money to get it. The Landpride disc works great and is built much better than any KingKutter disc.
   / Chance to buy a disc harrow, help please #4
I've been looking for one myself. A local used implement dealer has some nice older units, very heavy for around $500. You'll definitely want the weight of the heavier unit for it to be of any value to you /forums/images/graemlins/smile.gif
   / Chance to buy a disc harrow, help please #5
I agree, get the heavier one. It will cut in better. Otherwise, you'll be trying to add weight to the angle frame one to make it work.
RobS
I thought of adding weight to the King Kutter, but do I really want to mess around with that? I find at times I spend more time trying to make an inferior piece of equipment or tool work right, so I'll probably go for the better piece this time. I would buy used, but can't find one locally in good shape and at a good price.
   / Chance to buy a disc harrow, help please #7
By all means get an older, and heavier disk. I recently bought a 12 ft. tandem disk (an International, I believe) for around $1500. It's built like a tank and heavy enough to sink the Queen Mary.
   / Chance to buy a disc harrow, help please #8
How much horsepower do you need to pull a 12 foot disk?
   / Chance to buy a disc harrow, help please #9
You won't pull one with a CUT I can guarantee you that. You're probably looking at 60 or 70 hp, possibly with a smaller hp but you won't pull it very fast.
I'm pretty much limited to 6 foot due to the areas I want to disc over. Some are woodland grass roads that I'll overseed, others are strips along woodland edges for food plots. Also, I have a 40HP New Holland with R4 tires.
2016 Chrysler Town & Country Van (A51694)
2016 Chrysler Town...
2014 Infiniti QX60 (A51694)
2014 Infiniti QX60...
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
Payment Terms (MUST READ) (A50775)
Payment Terms...
2004 JOHNSTON STREET SWEEPER (A54313)
2004 JOHNSTON...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
