Gordon Gould
Super Member
- Joined
- Apr 1, 2007
- Messages
- 6,662
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
My glow plug relay would intermittantly chatter and when it did starting the tractor was harder. I thought I better take care of it before winter. I was told the problem was either the glow plug relay or the controler. I went with the relay first because it was cheaper.
From the Messick's diagram I knew they were both in the upper right and behind the dash panel. I took out all the screws and bolts I could see that were holding the dash on. It doesn't move much after that and you can't get to the connections and screws behind it. So next I took out the four bolts holding the inverted horseshoe shaped plastic cowelling behind the dash. I could see this would give me the access I needed if I could just move it out of the way. But there was an invisible fastener of some type underneath and dead center on top. Being plastic I was afraid to pry or bend to much so I worked very carefully. To make a long story short I finally discovered the plastic cowell was really quite flexable. To get it off you have to pull out the bottom left side enough to get your arm and hand with a small 12 mm wrench up into the very top. Then feel for the bolt buried up in there. Once removed you can easily get the cowell out of the way. You can see the nut plate welded in up there.
Pretty tricky of Kubota to do that I thought.
So maybe this might help someone and save them a lot of time or a broken cowell someday if they have a good memory.
