changed hyd fluid
   / changed hyd fluid #1
sam5570
Veteran Member
south west virginia
new holland tn70
well i changed all my fluids in my tn70 today and i had what i concider alot of metal on the magnet on the rear drain on hyd fluid. i hpoe i don't have some kind a problem. has anyone else had this? been about 5 years sence changed.
   / changed hyd fluid #2
"A lot of metal" as in filings or chunks? Filings are normal over that length of time and the magnet is doing its job keeping them out of the hydraulic system. I am assuming that you logged 1,000 to 2,000 hours over this period.
   / changed hyd fluid
it was just small stuff real small. 400 hrs on the tractor and 90% of that hard hrs bush hogging.
   / changed hyd fluid #4
The filings are probably coming from normal wear of the work you are doing plus from the initial break-in of the gears. Magnetic plugs are used for this reason.
1993 Mono Dump Trailer (A50514)
1993 Mono Dump...
2014 UTILITY 53FT DRY VAN TRAILER (A51222)
2014 UTILITY 53FT...
2015 PETERBILT CLASS 8 CEMENT MIXER TRUCK (A51243)
2015 PETERBILT...
RoGator 844 sprayer (A50490)
RoGator 844...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
2013 Mack GU713 T/A VacCon Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
