Changing back to Super UDT
   / Changing back to Super UDT #1
botalvr
I am going to change back to super udt, and my concern is that I will have some of the fluid I am using now remaining in the FEL. Is there any way I can completely drain everthing out before refilling with the right stuff?
Thanks!
   / Changing back to Super UDT #2
I am guessing that the short answer is NOPE.....all of the implements are filled with the old fluid. You would have to completely empty the FEL and any other toys, I mean tools that you have used.
Most fluids, even synthetic, are compatable with one another. Check the label and make sure.
   / Changing back to Super UDT #3
Do you still have the Super that you removed? If so, maybe you could drain the current fluid, re-install the old Super run for a while and drain again. At least it would lessen the amount by mixing it.
Just a thought as my old Super is still sitting in jugs at the house because I haven't taken it anywhere to dispose of yet.
   / Changing back to Super UDT #4
I wouldn't re-install old fluid- especially in this application. The last thing you want are contaminants in the old fluid back in your hydro system.
Even with the fluid left in the hoses and lines, draining and refilling will replace 99.8% of the fluid. What little remains will mix with your new fluid will not be detrimental.
2013 Jeep Patriot SUV (A50324)
2013 Jeep Patriot...
2024 WABASH STEP DECK TRAILER (A51222)
2024 WABASH STEP...
Westendorf Gravity Wagon (A50514)
Westendorf Gravity...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
