StickMan
- Joined
- Nov 3, 2008
- Messages
- 12
- Tractor
- Farmtrac 360 DTC
As several have pointed out, starter should be fine, but as Mike states, don't forget about lights.
I converted a Ford 8N from 6 to 12 and everything worked fine. The lights even worked for about 1.2 seconds (really bright, then really dark). Switched them over to 12v, and all was good.
One other thing I did was to replace the ammeter with a voltmeter. When I would start the tractor, the voltmeter showed 12v. Cranking up the RPMs got it to jump up to around 14 - where I thought it should be. Only once had to jump the terminals to reenergize it when it wouldn't start charging on its own.
Eventually had to switch out the ignition switch, but that may have been related to age rather than the 6 to 12v conversion.
