changing gear oil in finish mower
   / changing gear oil in finish mower #1
jmt1271
Platinum Member
MO
Kubota L2501
i just bought a used woods rm550 rfm. i want to change the gear oil and need to know the process. what weight oil? also, does anyone know where i can get an owners manual? thanks.
   / changing gear oil in finish mower #2
If you have Adobe Acrobat Reader, here is your manual
click here
i found the manual. but it doesnt show the process for changing the gear oil. I dont see a drain plug.
I am also having trouble locating a source for the O-ring that goes around the dipstick.
Guys, I am surely displaying a high level of ignorance, but I have to ask. How do you drain the old gear oil from this Woods RM-550? I cannot find a drain plug. Do you have to remove the top cover and siphon it out? I downloaded the PDF manual from Woods' site and it does not address it. I have a bad O-ring seal around the dipstick and I managed to get H2O in the gear oil and now it is milky and must be changed. Help please. Also looking for online source for parts, need a new O-ring and might like to add a center anti-scalp wheel.
   / changing gear oil in finish mower #6
I suspect that you'll need to remove the gear box from the mower, remove the top cover and invert the gear box to drain all of the contaminated gear lube or invert the mower and do the same thing.
You may be able to siphon from the top but the water is heavier than oil and will be all the way in the bottom. In all probability, there is a bearing at the lowest point (just above the lower seal) and that will make siphoning even harder. I don't think that I would want to chance leaving a bearing full of water in the bottom.
Page 22 of the on-line manual provides the instructions for removing the gear box.
I removed the top cover and siphoned all the contaminated oil I could, then wiped it out. It appears I got all 99.99% of it. I added new oil and will run it for a while and then change again. You guys think this will be okay?
I ran it for about one minute then looked at the oil, it appears normal. I will keep a very close eye on it.
   / changing gear oil in finish mower #8
On my rotary mower, I just picked it up, tilted it and drained it via the fill hole. I used my pallet forks. I took it up very slowly. Worked fine. Filled it and all is well.
Bob
   / changing gear oil in finish mower #9
My Bush Hog rotary mower takes 80-90W. If you are unsure, call Woods.
Bob
   / changing gear oil in finish mower #10
I recently changed the gear oil in my rotary tiller and I simply used a hand pump. I imagine you can get them at Sears, local hardware store, etc. They also have electric ones out there.
Electric Oil Drain Pump
You should be more than fine with what you did. Next time, I would get a pump and simply stick a tube through the drain hole. The electric one is nice since you can move the tube around the gear box while it is pumping.
I imagine that you can get a similar O-ring from any local hardware store.
BTW, have you fixed your iMatch top link situation? Be careful about using it the way you had it. Nothing is preventing that top link from popping out during transport.
2015 Nissan Frontier S Crew Cab Pickup Truck (A50323)
2015 Nissan...
2013 RAM 4500 (A50323)
UNUSED AGT XZ20R EXCAVATOR (A51243)
UNUSED AGT XZ20R...
2025 CFG Industrial TK35R Mini Track Loader Skid Steer (A50322)
2025 CFG...
TEST BID LOT (A50774)
