changing gear oil in finish mower
   / changing gear oil in finish mower
Neophyte said:
I recently changed the gear oil in my rotary tiller and I simply used a hand pump. I imagine you can get them at Sears, local hardware store, etc. They also have electric ones out there.
Electric Oil Drain Pump
You should be more than fine with what you did. Next time, I would get a pump and simply stick a tube through the drain hole. The electric one is nice since you can move the tube around the gear box while it is pumping.
I imagine that you can get a similar O-ring from any local hardware store.
BTW, have you fixed your iMatch top link situation? Be careful about using it the way you had it. Nothing is preventing that top link from popping out during transport.
I have yet to fix the top link situation. I found the correct bushings for the bottom, but not the top.
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
NEW Work Saver Skid Steer/Sub Compact Grapple (A52748)
NEW Work Saver...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2018 Ford Transit 250 Cargo Van (A51692)
2018 Ford Transit...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50323)
2016 Big Tex 14LX...
