Charcoal making and iron smelting? Well, almost.
   / Charcoal making and iron smelting? Well, almost.
Limestone? Thanks! I'll pass that information on to Dean, as he's the brains behind the madness. A few changes to the furnace may help, as you say, but we don't want to use any propane. The original premise was if the ancient Romans could smelt ore with charcoal, so could we. We already cheated quite a bit as it is, but we want to stick to our guns with the fuel. We have lots of homework to do before we try it again... probably next summer.
Thanks for the heads up on the IR rays. Good thing to know! I see goggles in the near future.
Joe
   / Charcoal making and iron smelting? Well, almost. #12
Thanks for the tip. I was actually wondering about using a kiln for such a purpose. Now... Who in my area has a kiln?
Just about any college or high school art department will have a ceramics class. If they don't want to "play" with you, they will know a potter who does! Cone 10 is 2400 degrees, hot enough to 'git 'er done'.
   / Charcoal making and iron smelting? Well, almost. #13
Iron Furnaces
Festival focuses on overlooked origins | Go Lackawanna, Scranton, PA
we have an iron fest/art fest every year. the iron furnaces are huge!!
Congrats, there are a lot of backyard metal casting sites. They also have a lot of different forge/casting designs.
I melt aluminum, and have iron forms that i cast them into thats fun also.
You can do vaporization casting once you get it up to speed, using styrofoam forms burried into damp general purpose sand. Just cast these outside.
I have poured bronze, aluminum, silver(lost wax), and glass. Once you get that forge fired up your hooked.
   / Charcoal making and iron smelting? Well, almost. #14
Just about any college or high school art department will have a ceramics class./QUOTE]
Ceramic kilns are not high fire.:)
   / Charcoal making and iron smelting? Well, almost. #15
I don't think that a Kiln will work. You must have the blast of air to smelt the iron from the ore.
   / Charcoal making and iron smelting? Well, almost. #16
The smelting furnace we had in college was rigged from an old vaccum cleaner.
before I had my welder, to cast my aluminum, I had a local welder make me a steel crucible, and some molds. its basically some pipe with a bottom welded on and two chain links (one at the top, one at the bottom) welded so that you have something to grab. I use tongs, and the hook from a turkey frier to move the crucible when its hot.
New/Unused Quick Coupler (A57454)
New/Unused Quick...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
2007 LUFKIN END DUMP (A58214)
2007 LUFKIN END...
WACKER NEUSON SM120 STAND ON SKID STEER (A52709)
WACKER NEUSON...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
