cheap drag-harrow
/ cheap drag-harrow #1
atightwad531
Mullica Hill, NJ
ariens
I am a small time farmer and need a drag-harrow for my lawn tractor to do my horse's paddocks. Any suggestions? Thanks!
/ cheap drag-harrow #3
Frame a small "wall" and side it with lapped boards, Hook two chains to it and pull with the laps so it will slide over things instead of catching. Make out of hardwood, pallets ect. should work well. Like dragging a hand saw backwards. My dad did this years ago to spread piles of cow pies where the cows spent a lot of time.
/ cheap drag-harrow #4
Some old truck tires chained together will smooth the "road apples", if that's what you need!
/ cheap drag-harrow #5
Not trying to hijack this thread but how well would the tires work on a looses gravel road bed.
/ cheap drag-harrow #6
A piece of 4' pipe with chain thru it to tie on to the tractor. Add some 4' chain link fence to the pipe, 4' to 6' long should do it. Will break things up and not grab everything like the ones with spikes.
/ cheap drag-harrow #7
An old, but sturdy set of box springs from a twin bed will do it too. We have used those to smooth over food plots and to cover the seed, that is, until we got better attachments to do it with. As suggested, a few tires bolted together in a "V" will work too.
/ cheap drag-harrow #8
They're not really cheap but we have a selection of chain harrows here on our website. The 4' should work fine behind a garden tractor. Our chain harrows ship free to a commercial business or supporting freight terminal within 1,000 miles of Newton, NC.
Here's a video showing one in action:
/ cheap drag-harrow #9
they can work good.
I made this one essentially for free.
On the way home from work one day i simply stopepd andd picke dup every tire and rim i saw on the side of the road.. picked out the best of those.. grabbed 3 old rusty sign posts out of the scrap piple.. did a lil chop saw and buzz job on the welder.. grabbed a few old rusty nuts and bolts out of the salvage bin.. bolted the tires together and into the frame.. drilled some holes on the bottom side of the tire sidewalls so as to not hold water... workks great to bust up clods / maneuer balls.. smooth a round pen.. and works decent on gradel. for gravel, add a fence post, 4x4, railrod tie or old pipe behind the drag.. rope or chain it on to trail the drag a foot or so...
here's one i pull behind my farmall C
http://www.tractorshed.com/gallery/uptest/a58097.jpg
/ cheap drag-harrow
Thank you. That sounds like my best bet. I will get one from the thrift store. Yay!!!!
/ cheap drag-harrow #12
I used a chain link fence section with old tires tied on top for the hunting club food plots for years
/ cheap drag-harrow #13
Soundguy said:
they can work good.
Thanks. I think this is what I will do.
/ cheap drag-harrow #14
i need to go put out some seed.. afterwords i'll be using that drag again.. probably use the C as well!
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
Utility Cart (A59231)
2016 FORD F-250 (INOPERABLE) (A60736)
2016 FORD F-250...
2010 Case 580N (A60462)
2010 Case 580N...
Toro Reelmaster 6500 D (A61166)
Toro Reelmaster...
2019 International LT625 Sleeper 48" (A62613)
2019 International...
