Cheapest way to try my hand at making hay?
   / Cheapest way to try my hand at making hay?
Wow, this is a lot of good info. I gotta get readin'! Thank you all.
   / Cheapest way to try my hand at making hay? #13
I have an L3830 and I don't have enough PTO hp to run a square baler (30hp) - not sure you would either. Usually it requires a bigger tractor. - Mike
I've seen it before, a guy I know had never fertilized his fields and he was getting about 1/3 the yield he should have been getting, so he fertilized. Then found out he did not have enough tractor and had to hire it done. The more fertilize the bigger the tractor you will need. it's that simple. I would also agree, a 30hp PTO tractor would be questionable.
Note: Rain and haying, those uncontrollable circumstances will get you every time, well almost.
   / Cheapest way to try my hand at making hay? #14
I ran an old square bailer off an M John Deere just for kicks back in my college days. As long as I didn't overload it, I was able to run just fine. The M has 12HP? IIRC.
   / Cheapest way to try my hand at making hay? #15
We have an L3830 and it does our hay just fine. We have a 9' mower conditioner, a 18' Enrossi tedder, a side delivery rake, a small square baler with a kicker and 2 wagons. We have to slow down a little in the heavy stuff, but it works well. The tedder was new in 2009 but everything else is 30+ years old. Before we got the L3830 they did the hay with a model M farmall. It worked, but it took 30mins to get it to start some days. The Kubota starts right up no matter what.
Aaron Z
   / Cheapest way to try my hand at making hay? #16
Once you get that flywheel on the baler spinning, doesn't take much HP to keep it going. As kid my dad & I baled many 1000's of bales with Super H the only constrant was how much we piled on the wagon pulling behind it. If dropping it on the ground to pick up later, won't take much to run the baler.
   / Cheapest way to try my hand at making hay? #17
Be ready for break downs. Every time i go to make hay i end up breaking down or something. I run a mf round baler, sickle bar haybine with roller, and an 8 wheel vrake.
The v rake works so much better then the roto rakes. I had one and it never gave me big enough wind rows for my baler. My round baler requires a lot hay to feed evenly. When you take your baler over your wind rows move in a zig zag over the wind row.
Making hay is not as easy as people think and it is not a fast process.
MAKE SURE YOU CARRY A FIRE EXTINGUISHER
Also if you use a round baler expect to replace bearings every year. Just the amount of weight and stress even with maintenance you will have to replace the flange bearings and they are not cheap. Last year my neighbor was helping me make hay and he was pulling my baler with his 2-135 white and had a bale start on fire. He got the bale out of the baler before it could catch it on fire as well. Had to hurry up and get the fire department out there, if it wasnt for me being close with the four wheeler and my big fire extinguisher we would have lost most of the field
Last year i took my 12 foot disk and went across my fields one way, then went 90 degrees to that, then 45 to that. Also when you go to make your turns lift your disk so you are not leaving ridges. After going those three directions you will have broken up most of the sod, then you can go on and plant, then run over it with a cultipacker to level and smooth the field. When you go to disk be ready to go find weight for your disk. My 12 foot disk did not have enough weight to cut up the sod in my field. Then again it had been 5 years from the last time it had been disked.
The last and i feel most expensive part of hay is the seed its self.
   / Cheapest way to try my hand at making hay? #18
My memories from "back in the days" was that balers were the most maintenance intensive machines on the farm, even worse than corn pickers. It was the one machine that most farmers didn't own, preferring to pay someone else to bale instead of taking care of the equipment.
Check around and see if someone would be interested in baling for you.
   / Cheapest way to try my hand at making hay? #19
+1 I think there was a thread about this last year. :thumbsup: I would get a 2 1/2 gallon pressurized water. They are charged with air so anyone can recharge them.
   / Cheapest way to try my hand at making hay? #20
Several questions need to be asked:
a) Is this a hobby? Or will this be a business venture for profit?
b) How many acres will you be haying?
c) Is the hay for your use or do you plan to sell it?
d) What size and hp tractor will you be using?
e) What type of hay? (grassy based or leaf based like alphalpha)
Theoretical answers:
If you plan to use the hay yourself then you really do not even need a baler assuming your acreage is modest. Balers have only existed for 80 years or so, but hay has been put up for centuries without a baler. Hay can be put up loose in a barn hay mow, or it can be shocked and stored outside. (Only if you plan to sell it for profit then you will need a baler).
As for cutting: a hand scythe can be used for small acreage, although I will not cut by hand. A bush hog while not the best tool can actually work pretty well if set-up properly in grass hay, but will not work well in leafy hay as you will lose lots of leaves. Added benefit of the bushog is that it sorta conditions the hay for faster drying plus tenderizes stemy grasses to make them much more palatable to the animal that eats it. Downside of the bushhog is that you will definitely lose some of your potential yield (estimating 20% - 40% yield loss as compared to cutting with other methods), but if this is a hobby who cares - you already have the bushog, and they require next to zero maintenance. Sickle mowers is the next cheapest cutter up from a bushhog but they require quite a bit of maintenance but any small tractor can run a sickle. From here there are also drum mowers, haybines, disc mowers, and discbines - some are suitable for small tractors and some are not.
Small acreage: If you have small acreage it will take years to make a profit if you purchase expensive reliable equipment. For small acreage, then older stuff can be had pretty cheap, but I hope you like working on it (I actually enjoy working on my old junk, but some people hate turning wrenches). That said, I have still yet to turn a profit, but am close to breaking even and do enjoy it as a hobby.
If you have a small tractor: Modern mini-hay balers is available brand new (e.g. MicroStar) that will work on very small 15 hp tractors not much bigger than a lawn mowers, but it is prohibitively expensive and can usually only be found brand new - at $15k they are too expensive for small acreage operation. That said, there are old vintage balers that will work with your small low hp tractors in the 25 hp range, but these balers will be 40-50 years old and full of wear - so again hope you like to tinker. Unfortunately newer balers from the mainstream manufacturers require more horsepower than the older ones did. Newer balers will need 50 hp or me as they have much more capacity than the older ones did.
Literally hours worth of reading on this subject if you do some searching on this site and Yesterday's Tractor for vintage baler info. Just remember there is no such thing as easy money in hay.
Here is my hobby/junk operation with a 1978 L285 Kubota (26.4 max PTO hp at WOT, but closer to 23 hp with throttle set at 540 PTO rpm). A 1940's antique JD 594 hayrake, and a 1960 NH 65 compact baler (smallest of the vintage balers). Tractor looks terrible, but runs excellent. I spent considerable time on the Rake and baler getting them usable.
My helper (my wife) sabotaged my pics - she hates cameras and painted herself out.
2018 Dodge Journey SUV (A59231)
2018 Dodge Journey...
2025 Ford Transit Cargo Van (A56858)
2025 Ford Transit...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
New Holland 650 Hay Baler (A53317)
New Holland 650...
