Check hydraulic fluid level/3 vertical plastic plugs
   / Check hydraulic fluid level/3 vertical plastic plugs #1
jimnor46
Elmendorf Texas
Mahindra 4025
Have a 2014 4025 trying to check hydraulic fluid level.Also like to know what 3 vertical plastic plugs on each side of 3 point hitch housing and what appears to be plastic filler cap on top of 3 point hitch housing. Owners manual doesn't say what these are for. Also where to check power steering fluid. Picture in owners manual isn't like mine.
Thanks...
   / Check hydraulic fluid level/3 vertical plastic plugs #2
Sorry, I don't have the answer, but I'd like to know, as well. My 3 pt. hitch won't lift. Tractor, just, had it's initial service. They did re-route the dual remote lines at that service. Searching forum now for answers. Can not find my manual and Mahindra online manual won't load. :mad:
Near as I can make out, the plastic plugs don't do squat. I just decided to unscrew some and see what happened and they appear to just be"casting " screw holes that are blanks. I found several more on different locations all over the engine block. Unscrewed the plugs, stuck a scratch awl in several and they just dead end.
As for the Mahindra owners manual, near as I can figure it's almost worthless and I'm not paying $90 for a service manual that some people on TBN have said are just as useless. I guess we are supposed to take the tractors to a dealer for anything other than just adding gas. I thought Chinese equipment was bad, had better thoughts for Mahindra, being of Indian origin, guess I was wrong.
   / Check hydraulic fluid level/3 vertical plastic plugs #4
Thanks for letting me know that about the plugs. Did you, ever, figure out what that plastic filler cap (without a dipstick) is for?
On my end, after perusing the forums search and seeing the suggestions of made to others with a similar 3 pt lift issue, I went out and checked the levers for the dual remotes. One had been bumped out of neutral and once it was back in neutral the 3 pt lift functioned perfectly :D
UNUSED FUTURE HYD HOSE BUNDLE (A51244)
UNUSED FUTURE HYD...
CASE 586H STRAIGHT MAST FORKLIFT (A51242)
CASE 586H STRAIGHT...
2013 AMSIG S/A Solar Towable Message Board (A50322)
2013 AMSIG S/A...
2018 BOBCAT T450 SKID STEER (A51242)
2018 BOBCAT T450...
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A52128)
Kubota BX2680...
