Hey Bill,
Don't blame Detroit automakers. As you probably won't know, Toyota and Honda have joined the 'gas guzzling' truck race with gusto and their rigs do far worse than the Chevy's. They don't have active fuel management (displacements on demand). and won't have 2 mode hybrids around for quite a while.
The fuel economy one gets is prescribed by the Federal emissions laws which rule out high efficiency combustion because of temperature issues (nitrous oxide generation). This means that the combustion cycle is down rated to keep from getting the best thermal efficiency (and best mileage). Then, a catalytic converter is added to achieve the Federal mandated output gas mixture and an energy source is needed to power the converter. You guessed it: extra gas must be passed thru the combustion chamber to heat the converter.
All this because politicians never made it thru chemistry 101.
The same deal goes for diesels. Efficiency must be downgraded to prevent the high temperatures of optimum combustion. Since Europe has different exhaust gas mixture rules, they can run more efficient diesels. Hence the urban legend that they do better. Unfortunately, they are illegal in the US to import because they don't pass US emissions requirements (however some EU automakers are bringing them in under the radar).
Wait until you see the new GM Tahoe hybrid. Its a real 2 mode, not a Prius assist. The engine just charges the battery. Trailer all day with it. AC, defroster, power steering, etc.
Only remaining problem is that the Blind Association is mad because the 2 modes are usually silent and they need a presence alarm to tell the pedestrians that they are coming. Ain't that a batch ?
If you really only just want to save gas, air up your tires to 45 psi, saw off the brake pedal, close up the windows and lower the tailgate. The results will astound you...
Just don't blame Detroit. Toyota's Tundra is at the top of the gas guzzler pile. It's a heavy truck for its market class: a hurry up design to compete with the domestics. The brakes are way too small as a result, and the trailer towing capacity is lowest of all of them (you must subtract the weight of the truck from the total package to get the real capacity, Rembrandt).
As far as fuel economy is concerned, your jet plane has the worst emissions/highest nitrous oxides and carbon dioxide output per mile of anything other than an Abrams tank.
I like the tank, though. Be the first one on your block to be the last one on your block.
