crashz
Elite Member
I had an interesting issue with my truck recently. I pulled into the driveway, behind my truck, and noticed that the differential cover was wet. I climbed underneath, and checked the fluid, and it was up to the plug. Hmm.
Noticed that the cover was wet on the bottom and around the gasket area. The pinion seal was dry as a bone. Not expecting much, I grabbed a cover bolt and was horrified to see that I could tighten it by hand, and at least a turn or two!
All of the bolts were loose to some degree. Not exactly sure why, but I assume that the cover gasket has shrunk a little. I serviced it this past summer, and torqued the bolts to spec. I routinely check the fluid level, and rarely need to add any. Never paid any attention to the cover bolts though.
So just a word of caution: Check your rearend!
