Checking Axle oil level on BX
   / Checking Axle oil level on BX #1
RMatty
North Windham CT
BX 2350
Hey everyone, just changed the fluid today in front axle on my BX2350 and had a question on checking it. When you check the level on the dipstick do you push it all the way in or just rest it on the o ring to check the level. I went through the manual and couldnt find anything about it. I was wondering what the consensus was on the proper way to check it.
   / Checking Axle oil level on BX #2
Depends who you are, some people put it all the way in and others put it in to the o-ring. This is one of those topics that is discussed a lot, if you do a search I guarantee you will find topics on it but with people doing it both ways.
   / Checking Axle oil level on BX #3
I push it in all the way, but to be honest, I doubt it makes any difference.
   / Checking Axle oil level on BX #4
I wondered about that as well but decided to push it all the way in as that is how other dipsticks work.
   / Checking Axle oil level on BX #5
The BX axle doesn't breath, and air expands more due to heat than oil. I screw it all the way in so full is more towards extra oil than extra air.
   / Checking Axle oil level on BX #6
I believe that no matter what engine, transaxle I am checking, I always fully seat the dipstick. If it at the full mark, its good, if not add. This way if it supposed be checked without fully seating it - the full mark would be within the normal range.
Now with that said - I always fully seat the front axle dipstick all the way down then pull up to check second time after wiping first time. I never trust the first pull.
2023 Bobcat T770 (A60462)
2023 Bobcat T770...
2434 (A60432)
2434 (A60432)
Husqarvana Riding Mower (A56857)
Husqarvana Riding...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61306)
2021 Takeuchi...
