Pilot
Veteran Member
- Joined
- Nov 20, 2004
- Messages
- 1,208
- Location
- Oregon
- Tractor
- JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
I have found several used tractors available that will fit my needs, 20-28 HP, FEL. A few JD's a couple Kubota's & F-NH's.
I need a checklist of things to check when looking them over. Here are a few things I have already, how about adding to the list:
How easily does it start in cold weather?
Check the exhaust manifold before starting to make sure seller didn't run it before you arrived to make sure it would start easily.
Does it smoke?
Check breather for blow-by.
Check all pins to make sure they are still tight.
Tires: No cracking, tread still good--or make sure the price is right & replacement tires are available in the right size at the right price.
With a load on the 3 pt. hitch, does it bleed down?
Overall condition, does it look beat up?
Leaks?
Does it smoke?
Leaks?
