Chevrolet Astro Van
   / Chevrolet Astro Van #11
Nasty135 said:
KB, If it runs ok cold then gets rough as it warms , check EGR valve .. If this is a throttle body injection and not the multi-port (not real familiar with multi's but could be same issue), I would also look at the Base of throttle body where the vacuum lines attach for a carbon build up clog that is choking the vacuum off (usually high mileage issue) also possible O2 sensor or Maf sensor, All this is assuming the airfilter is clean and the pcv is good ... a distributor cap could cause a problem but is generally found to be the culprit under load with a miss. Need more info when diagnosing like engine cold/warm when it misses idle/under load, how many miles, last tune-up etc.
Good Luck
Not a real mechanic , but I play one on TV ;) ...
Oh and I own two Astro's 325K & 190K which means nothing...
I'm in agreement ,02 sensor or maf. Of course, there's not much info. to go on.
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
2015 DODGE RAM...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A55301)
Adams Load Out...
2000 Ford F-250 4X4 Service Body Truck (A55788)
2000 Ford F-250...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
