Dana Warner
Sounds like a MAF problem or an intake leak after the MAF. Low fuel pressure is easy to check too.
O2 sensors rarely go at the same time like that and if they did, you would see a code for at least one.
Since both sensors are reading a lean condition then the problem is something that affects the engine on both banks. I think it's still a MAF sensor or intake leak. I've received bad MAF and other electrical parts from stores before.
If you have the old MAF, plug it in and see if you get the same symptoms as before. When is the last time you cleaned the K&N? Is it possible you over-oiled it?
timswi said:I've run K&N's in my last 4 GM pickups and never had a problem...Odd though that it appears that the dealer removed the K&N warning sticker when I had it inspected...Was going to call and complain, but I forgot about it...I'll argue with that tech anyway, he put a 12/12 inspection sicker on it with a 12/13 emission sticker...I'll argue eyesight
I've had one in the wife's Hummer for 3 years and never had an issue.
