Chevy Volt Halted. Who did not see this coming?
Status
Not open for further replies.
   / Chevy Volt Halted. Who did not see this coming? #182
...Volt met its design goals and the Volt works as designed
Thank you I haven't laughed so hard in a long time. Wait let me clear the coffee off the screen that came spewing out of my mouth from laughing...there that's better.
So when did they actually design the volt to spontaneously combust and burn people houses down. Bwahahahahaha.
Man oh Man you Union Obama Fan boys really have a bad case of Kool aid drinking don'tcha.
I'll give Obama respect when he earns it. When he does things that actually help this Country, when he wears an American flag on his lapel, when he actually hold his hand over his heart during the National Anthem. When he stops hanging around racist radicals.
   / Chevy Volt Halted. Who did not see this coming? #183
Cat_Driver,
Senator Obama with an American flag in his lapel.
President Obama with an American flag in his lapel.
   / Chevy Volt Halted. Who did not see this coming? #184
With Obama, he's earned everyones critisism.
1. Since you are a fan of the Volt
2. The reason we don't like the Volt has nothing to do with a hatred of electric cars. Nobody cares about electric cars!!!!!
3. While you think it's because we all hate the Volt and are too dumb to understand how it works, what you don't get is that we don't care how it works.
4. I want to see results that make sense financially.
1. I never said or implied I am a fan.
2. I agree, electric is not the way, we have yet to find a method of storing energy efficiently.
3. I never implied anyone was dumb about anything.
4. Me too.
   / Chevy Volt Halted. Who did not see this coming? #185
If I look up Cat_Driver in the dictionary, I will find the definition of a drama queen.
There has never been a single report of a Volt spontaneously combusting and burning down anything. I challenge you to post a credible link of prove a Volt did what you recklessly claim. In previous threads, someone (may be you) post the same nonsense and everyone was discredited by links to news posts vindicating the Volt.
I am neither an Obama fan or a member of any union.
   / Chevy Volt Halted. Who did not see this coming? #186
The Volt has burned in fires. The problem is the batteries require a cooling system full of coolant. And when that coolant leaks out the batteries get hot real hot and burn. Now in an accident even a small accident if that system leaks it turns into a fire. Even a coolant leak in your garage will cause the batteries to over heat and catch fire. EVER HAVE A RADIATOR LEAK? Well for the Volt that means a huge fire. Sorry, to bust your bubble it's just a fact.
HS
   / Chevy Volt Halted. Who did not see this coming? #187
The Volt has burned in fires. The problem is the batteries require a cooling system full of coolant. And when that coolant leaks out the batteries get hot real hot and burn. Now in an accident even a small accident if that system leaks it turns into a fire. Even a coolant leak in your garage will cause the batteries to over heat and catch fire. EVER HAVE A RADIATOR LEAK? Well for the Volt that means a huge fire. Sorry, to bust your bubble it's just a fact. HS
I think the circumstance your are referring too is a Volt fire from the crash test vehicle used which caught fire three weeks after the crash test. The root cause of the fire was from a leaking cooling line which caused corrosion on the battery which ate into the lithium layers. Once the layers began to short, the current potential was released causing the heat need to cause combustion.
Unlike other battery chemistry, Lithium will release its charge all at once.
The other fire linked to Volt was in the garage of an owner in North Carolina. The cause of this fire was traced to the charger being used to charge the vehicle. It remains unclear if the charger being used was installed correctly.
The battery needs to be cooled when the vehicle is under power of the battery, that is when lithium chemistry creates heat, so a loss of coolant is not going to cause the battery to catch fire unless the coolant leaks on the battery. Everything I said can easily be self-discovered with a few Google searches.
I'm not defending the Volt or GM. I simply want to present the facts and not carry on the silly propagation of Internet rumors or people's uninformed assumptions.
So houstonscott, like it or not, here are the real facts about the Volt fires.
   / Chevy Volt Halted. Who did not see this coming? #188
My point is you tried to make people think that Volt's had not caught fire or have a fire issue, and clearly they do. Anything with LI batteries do. My point is they burn, I remember the video of guys like you saying laptops can't catch fire and one caught fire burning during the press conference. LOL. Volt is not just a looser technology, its dangerous.
HS
   / Chevy Volt Halted. Who did not see this coming? #189
I looked up Monster5601 and found the words HEAD BURIED IN THE SAND.....
I'm getting pretty tired of home schooling Union Fan boys, but here I'll do it one more time.
"GM ANNOUNCES PLAN TO MODIFY CHEVY VOLTS TO PREVENT SPONTANEOUS EXPLOSIONS"
Read it and weep Union Fan boy..."A number of Volts have been bursting into flames weeks after getting into accidents."
I report you decide.
GM announces plan to modify Chevy Volts to prevent spontaneous explosions / Scrape TV - The World on your side
Chevy Volt Again Suspected in House Fire
Video: Garage fire claims Chevy Volt and homebuilt EV *UPDATE
Chevy Volt Fires: Government Stops Investigating Itself After Announcing $1,500 Incentive For California Volt Buyers | Sad Hill News
Chevy Volt fire: What did NHTSA know and when did they know it?
video-garage-fire-claims-chevy-volt-and-homebuilt-ev
   / Chevy Volt Halted. Who did not see this coming? #190
No matter if he starts wearing a dozen lapel pins and holds his hand over his heart, we know it's just fake.
When he renounces Rev. Wright, Bill Ayres and Derrick Bell and Saul Alinsky, etc. we still all know it's just more of Obama's lies.
I have no respect for Obama and won't ever.
Status
SEED TENDER TUBE (A52708)
SEED TENDER TUBE...
2016 Komatsu WA380-8 Wheel Loader, S/N 15080, PIN# KMTWA13OCGA015080, Turbo Diesel Engine, Komatsu (A59076)
2016 Komatsu...
2017 Ford F-550 Duralift DTAX39 39ft Insulated Bucket Truck (A55973)
2017 Ford F-550...
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
BUSH HOG DISC (A58214)
Bobcat T590 (A53317)
