Chipper Chinese (Jinma) Chipper Revisited
   / Chinese (Jinma) Chipper Revisited #1
EdwardB
Michigan
JD 4410
Hi everyone - TonyC, markie61, DIYGuy and ken4210.
I followed the previous Chinese chipper thread carefully and am very intrigued by the product!
I was wondering if any of you had any further updates regarding the mechanical failures in the unit? Did you get them resolved? How is the unit after a summer of chipping?
I am interested, but I want to make sure the unit will be reliable.
Also, does Gary from Emerybuilt still carry them?
Thanks!
   / Chinese (Jinma) Chipper Revisited #2
I still like mine. I would buy it again and would recommend it, but only to those who are mildly mechanically minded (or greater /forums/images/graemlins/laugh.gif) It chips well, feeds well, and appears that it will last.
I re-engineered the feed shaft BEFORE I even used it and have not had one problems with THAT part. However, the self-feed disengage lever was hitting the sheetmetal on the belt/gearbox cover and would not disengage the feed mechanism (safety issue). I just lengthened the "notch" in the cover an inch or two longer (sawzall with metal blade) and it has worked since like a champ.
I don't know if I said in my review, but the several grease fittings were missing and a couple brass ones snapped off.
You will have to call Gary to see if he still sells them and check his stock levels. Hurricanes are now upon us.... /forums/images/graemlins/shocked.gif
Mark
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
2012 Toyota Camry Sedan (A56859)
2012 Toyota Camry...
2017 Kubota M7-151 Premium MFWD Tractor (A55315)
2017 Kubota M7-151...
SCAN TO RECEIVE TEXT UPDATES (A58375)
SCAN TO RECEIVE...
2018 Dodge Charger Sedan (A56859)
2018 Dodge Charger...
