Choosing a Tranny
   / Choosing a Tranny
The power is meant for cutting the grass, not pushing or pulling heavy loads.
My LT180 has the K46, yes it needs a tranny oil change/possibly new parts. It is a 2005 model, so it has worked for 14 years so far.
You might try heavier weight oil in the summer.
I'm not sure I can go heavier than the 5W-50 recommended by Tuff Torq. Are you aware of a heavier oil that would work in this unit?
   / Choosing a Tranny
Thanks -- that is a good price. Lord knows I've had this thing on & off the tractor enough times to have that part down. There were a couple interesting posts in there (#847, 848) that talked about use of Volvo Penta Synthetic 75W 90 Outboard Leg Oil.
With a little luck, I can keep this thing running enough to shop for a better option, as I still feel like the long-term solution is to find a heavier-duty tractor.
   / Choosing a Tranny #24
the JD GT series was a true garden tractor, and you can buy them restored for a good price. the IH Cub cadet is another one, like the model 107 HST which could use a scaled down version of any implement of a full size tractor. and the transmission could be easily modified for competition pulling with a 27HP motor and very wide tires, it will take that HP with standard tires though.. and it can accept a FEL, which was one of many accessories made by the OEM..
   / Choosing a Tranny #25
I am a fan of hydrostatic transmission. I had a JD318 and eventually went to a Kubota BX24. At one point I volunteered to mow a friends yard while he was waiting for a heart transplant. It was about two acres and he had a Craftsman with manual transmission. I hated it. 2nd gear was too slow and 3rd gear was too fast. After a while I borrowed a trailer and hauled my JD over. If you are mowing on a hill overbuy your tractor, you won't regret it.
Doug in SW IA
   / Choosing a Tranny #26
   / Choosing a Tranny
Excellent - thanks. I've seen good things about the Cubs. I see a fair number of JD 316's and the occasional 425 for sale, too -- as near as I can tell, these were fairly well-built, too, weren't they?
   / Choosing a Tranny
Doug in SW IA
Thanks - I sure didn't think of this yard as "hilly", but it appears maybe it's more so than I'd considered.
   / Choosing a Tranny #29
YES!. if the manufacturer sells a plow for it, it's a Garden tractor, (heavy duty). that's what you want for longevity, what ever you use the tractor for.. about the Cubs, I was referencing the Cubs made by IH, international harvester, decades old. the new one's don't compare..
   / Choosing a Tranny #30
When I finally changed the oil in my mower (JD 110) it was getting quite poor,
it wouldn't even do just the trimming.
I used Mobil 1 20w-50 it completely turned it around,
it at least doubled the power to the ground and doubled the time it was usable.
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55315)
Galvanized...
STORAGE FEES (A57880)
PAINT ROOM EXHAUST FAN (A54757)
PAINT ROOM EXHAUST...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A56435)
2014 Doyle Dry...
2000 Volvo VNL Sleeper Cab Truck, VIN # 4V4N21JF6YN250211 (A57453)
2000 Volvo VNL...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
