Cinder block chimney repair
   / Cinder block chimney repair
Thanks BAC,
I guess I will have to bite the bullet and tear it out to the roofline. I feel more confident building back up with blocks and putting some sort of faux stone finish on it.
   / Cinder block chimney repair #12
Yes, it was either painted or smathered with a thin, soupy layer of something like stucco. That's peeling off, big time, and would likely have to be sand blasted.
<font color="blue"> I am concerned as to why the joints are failing. </font>
I'm not an expert, but it looks to me like there is moisture migrating from the inside out. I'm afraid of heights, so haven't been to the top to look, but I believe there is a concrete cap around the flue that has failed, or, having been through other work done by the original contractor (who was ridden out of town on a rail after having been tarred and feathered, or should have been if he wasn't), it wouldn't surprise me to discover that the concrete blocks are exposed at the top. I also don't know exactly how the flue was constructed -- there are firebricks inside the firebox, but I don't know if the chimney is brick lined all the way up, or if the concrete blocks are exposed. I think it's brick, or possibly clay tile, I know it's not metal.
If it is moisture migrating though the clock and out the joints, it's far from happening at every joint. Most of them are in good shape, and it's only the thin, gruel-like coating (stucco wash or texture paint) that makes it look bad. But, a few joints have had chips of mortar break out of them.
Another indicator is the interior basement wall. It's really more of a full-height, dirt floor, "crawl" space, and the block walls are exposed. It forms the fourth wall of the chimney; the other three are an exterior projection from the foundation wall. The interior of the block wall at the chimney is damp after it rains.
It's been there for over 30 years, and has looked exactly the same in the 16 years I have owned it, so I don't think it's in any danger of falling down.
I had a mason who specializes in decorative stone facings look at it about 10 years ago, and he recommended tearing it down to the firebox and building it back up again before facing it. However, he considered himself an "artist" and wouldn't do the block work. We got involved in some other priorities and let it slide. But, now, the wood shake roof needs to be replaced (it was shingled with siding shingles rather than roof shingles, that dad-blasted contractor, again). We're planning on a metal roof, and would do the chimney work at the same time.
Now that we've got our rural acreage, we no longer have the desire to "get away" from our neighbors, and will likely sell the cabin. I have 3 choices. (1) Do nothing, discount the price for the work, and let the next owner do it the way they want it. (2) Do good repair work, get the increased value (it would be such a dramatic improvement that I should get a much larger return than the cost), and be able to sleep at night, knowing that the repairs will last. (3) Do just enough to make it look good and get the increased value at a lower cost. I would have difficulty doing this. All of the other work I have done on the cabin has been done "right" without much regard to cost. If I do the roof and chimney right, someone would get a very nice little cabin. I'll make a bundle regardless; prices have increased dramatically over 16 years.
I'm not sure if the damper was cast iron or heavy sheet metal; I'm trying to recall what it felt like the last time I reached up in there and manipulated it. The mechanism is broken, but I can still prop the damper plate up in full open mode, or lay it flat on the framework. If it was cast, then it wasn't very thick or heavy. The throat is formed with masonary.
It probably doesn't help, but I just found this picture of the hearth.
I want to install a metal roof as well. So, I want to get the chimney fixed before I tackle that.
Can anyone direct me to some sites that would show these faux stone coverings. I really have never seen them.
   / Cinder block chimney repair #15
if you are doing it to sell I would have someone insure do it and not do it myself. That way "if" something did happen (it is very tall) it would be their problem and not yours
   / Cinder block chimney repair #16
I think you are probably right. If the cap is bad the water is getting inside and working its way out even to the inside wall you described. If you had flashing leaking there would more than likely be a lot more water than you describe. I would have the flashing looked at though just to rule it out.
If the damper were cast iron then it would be quite thick, maybe 1/4". A steel damper is much thinner. Both can be replaced but the steel one can be much more difficult.
BAC,
Thanks,
That is exactly what I was looking for.
</font><font color="blue" class="small">( I have used a lot of Cultured Stone. You can look them up at www.culturedstone.com. )</font>
2011 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2011 DRAGON...
100 GAL FUEL TANK AND TOOLBOX COMBO (A53843)
100 GAL FUEL TANK...
2006 BIG TEX 16 T/A TRASH TRAILER (A53843)
2006 BIG TEX 16...
2019 TY-CROP MANUFACTURING LTD DRY BULK TRANSPORT TRAILER (A53843)
2019 TY-CROP...
PAIR OF 607 CHALLENGER PUMPS (A53843)
PAIR OF 607...
SCAN FOR HAULING AND FINANCING INFORMATION (A54756)
SCAN FOR HAULING...
