CK20 HST geyser of HST oil from dipstick check
   / CK20 HST geyser of HST oil from dipstick check #21
I bought three of those zerks for the front center bottom inner ram pivots since they seem to be in a damage prone area and also seem to be the kind of pivot that I want to keep lubed.
The dealer actually said they were typical for a Kubota excavator and the new ones threaded right in and now that joint is oozing with beautiful red EP grease.
Dealer called today. I stopped down to see what was done etc.
They called Kioti to find the tractor hydraulics / HST system is vented underneath the seat -- there is a tube that comes up that looks like an upside-down letter "J" just like the air vents seen on septic leaching fields and gas line vents I've seen coming out of the ground at least around here.
Turns out a mud wasp built it's tiny nest that sealed that vent off perfectly!!! :eek:
So I'm just amazed the chances of that happening etc. My tractor is garaged, but we all know insects can get into whatever they want to.
So Frank took the seat and tank off and unscrewed the vent tube and cleaned it out. Put everything back and filled the oil back up to the proper level.
It was about 2.5 hours of labor and they didn't charge me for it. They only charged me for pick-up and drop off of the tractor $75.00. I figured that was fair since this was not a warranty thing (they can't bill kioti for a wasp's choice of nesting), but just a freak thing of nature.
Tom plans to drop the tractor off thursday eve after close -- that's fine as I don't need the machine til this weekend.
Once I get the machine back, I will take pictures of where the vent exactly is so this is well documented for future reference.
I'm just amazed -- and I'm very happy there's nothing catastrophically wrong w/ the tractor. It was probably a couple or 3 quarts of oil that escaped during the geyser event, so I'm convinced no damage was done internally since it still had at least 4 gallons of fluid in there and all tractor functions were working even w/ some oil missing.
So I'm psyched... next time I will try not to freak out when issues arise... hoping my "wierd" problems with the machine are over...
Stay tuned for pictures when the machine comes home... I miss my orange girl!!!
   / CK20 HST geyser of HST oil from dipstick check #23
Good News!
I think I will go check my HST vent right now! :D
   / CK20 HST geyser of HST oil from dipstick check #24
We're still waiting for the tractor pull off between the 7510 and the CK20 too.:cool:
   / CK20 HST geyser of HST oil from dipstick check #25
Every time I stop by with my 7510 at Malk's house for the tractor pull, his tractor is busted!!!
I'll stop by this weekend with a can of bug spray!
Malk, my gear drive is going to pull that HST beast like it was a lawn tractor!
Ironmouse
(B7510 Gear, LA302 loader)
   / CK20 HST geyser of HST oil from dipstick check #26
Speaking of wasps...I have a propane house furnace with a 2 inch pvc vent pipe and last fall I could not get it to start. Looked it over and over. I finally called the HVAC guy. The wasps built a nest in the pipe during the summer and plugged it. hehe
   / CK20 HST geyser of HST oil from dipstick check #27
Hmmm, sounds like a small section of screen and a zip-tie are in order for all of us! Thanks for the tip.........!
RD
   / CK20 HST geyser of HST oil from dipstick check #28
Ouch !
You do realize this is the Kioti board...
We might have to slap that k of yours around some <grin>
   / CK20 HST geyser of HST oil from dipstick check #29
Ironmouse
So, when is game time? And what channel will it be on? Hope you figure out a way to load about another 500lbs on your tractor or that mean old CK is gonna pull you back even as your tires are spinning away.:) You guys should repeat the pull on different surfaces to compare the role of traction.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
SHOPMADE MANIFOLD TRAILER (A58214)
SHOPMADE MANIFOLD...
Forklift (A59228)
Forklift (A59228)
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2021 Husqvarna YTH18542 42in Riding Mower (A56859)
2021 Husqvarna...
