wallace
Veteran Member, Approved Advertiser
Highbeam, I am a little lost here .. let me tell you what we do and see if it may work for you.
We do use a electronic 3rd function. What it is, is you push a button on your loader joystick and instead of curling or dumping your bucket it will take the flow of hydraulic fluid from your tilt cylinder and put it to your "attachment" but as quick as you let go of the button the flow goes right back to your tilt cylinders.
We use these all the time for power angle snowplows. log grappels, and 4 in 1 buckets.
It is the eaisest and cleanest way of getting power out the front.
I have used stacked valves before but once you position your loader hight and roll angle you have to let go of the loader joystick and grab the other joystick to operate the 3rd function.
With the electronic valve you never have to let go.
