CK20S HST - Hi SUX!
   / CK20S HST - Hi SUX! #1
crabjoe
Ceciltucky, MD
Kioti CK20S HST
Today I went out to move a bit of dirt; then went well. Then when I went to bring the tractor up the hill in high, the thing wouldn't move. Fact is, it stalled.
I brought the tractor back to the house in Hi and decided to see if it would move in Hi on relative flat ground. I'm taking about 4 to 6 inches of drop for 20 feet. It was a NO go. The CK20s HST TLB is a DOG in Hi range. In low, I have no problems with it.
Now, can someone tell me if they run into the same issue with the CK20 HST TLB? It kind of sux to think that I can only use Hi driving around on level ground.
   / CK20S HST - Hi SUX! #2
That slush-pump drive eats a lot of HP:(
   / CK20S HST - Hi SUX! #3
how many hours on machine?
They are a bit low on power in high, but usually once engine is broken it they work ok. Also be sure your fuel filter is clean, any restriction could make the problem a big problem.
   / CK20S HST - Hi SUX! #4
Stalled! On a grade pitching 4-5" in 20'? No Way......are you sure the Parking brake wasn't set? It's easy to leave it on.
rim
   / CK20S HST - Hi SUX! #5
It definitely will put out more hp as it gets broken in. I can climb some pretty decent slopes in high gear, it all depends on rpms. I have 320 hrs so it's pretty broken in and whenever working/traveling in high gear, I run it at about 2800 rpms.
   / CK20S HST - Hi SUX! #6
howdy crabjoe
after reading your post I thought I would go give my CK20hst a shot in high range up the drive way. I didnt have a bit of trouble and it would accelerate the more I pushed the pedal. I all I have on mine is the FEL rear grader blade and the tires are loaded. Attached is a pic of my driveway.
   / CK20S HST - Hi SUX! #8
Were you flooring the HST pedal? HST responds differently than a regular gas pedal. Flooring a HST pedal can mean less not more.
Don
   / CK20S HST - Hi SUX! #9
I had same problem with my new holland tc 21d in high. It won't pull a slight grade in high but will not think about stalling in low. My backyard is about 15 degrees and low gear it is for me.
Brad
   / CK20S HST - Hi SUX! #10
I am at 8800 feet, dont have that problem. I can pull my driveway in Hi and it is about 10%. Now moving snow or something its low 4wd all the time.
2013 Chevrolet Impala Sedan (A44572)
2013 Chevrolet...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A43004)
2020 FREIGHTLINER...
2024 Chevrolet Silverado 1500 4x4 Pickup Truck (A44572)
2024 Chevrolet...
2023 Bobcat E32i Mini Excavator (A44391)
2023 Bobcat E32i...
2015 Ford Explorer AWD SUV (A44572)
2015 Ford Explorer...
2019 Club Car 2-Seater Golf Cart (A44391)
2019 Club Car...
