Oil & Fuel CK2610 Oil Change- Cranking Without Starting Engine Needed?
   / CK2610 Oil Change- Cranking Without Starting Engine Needed? #11
You can run it for 10 seconds (or longer) to warm up the oil and drain, or you can drain it without starting. I believe either way will work.
Filling the filter or whatever before installing it is personal preference or peace of mind. I put mine on dry and let the oil pump fill it. Done the same on all my cars and other pieces of equipment, and all my vehicles have 150K plus miles and haven't fallen apart on me.
   / CK2610 Oil Change- Cranking Without Starting Engine Needed? #12
There are oil on the bearings in the engine, running them for a few seconds before you have filled the filter and gain pressure doesn't matter at all.
   / CK2610 Oil Change- Cranking Without Starting Engine Needed? #13
I personally like to oil change a warmed up engine as the oil flows better when hot and in my mind the last bit of oil drains out easier/quicker/more completely. I've never worried about anything else. Never tried filling horizontal filters, but I do put a bit of fresh oil on the filter gasket, that along with not pretending to be Hercules makes for an easy filter removal at the next oil change! Lol.
E.
2007 Ford Five Hundred SEL Sedan (A55853)
2007 Ford Five...
2021 Ford F150XL (A53314)
2021 Ford F150XL...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
2006 Magnum 125 125kW T/A Towable Diesel Generator (A53421)
2006 Magnum 125...
19015 (A55788)
19015 (A55788)
2019 Cat D6 Dozer (RIDE AND DRIVE) (NEXT GEN) (A50775)
2019 Cat D6 Dozer...
