Clark Michigan/perkins 6.354 - no start
   / Clark Michigan/perkins 6.354 - no start #11
   / Clark Michigan/perkins 6.354 - no start #12
How many hours on this engine? When is the last time you did a leak-down or compression test? White/light grey smoke that lingers in the air is unburned fuel. To satisfy yourself, you can pop the valve cover and check the timing. Spill time it to check it closer. And FWIW, ALL diesel engines require a lift pump of some type.
I'm not sure of the hours, it's been running good, just all of the sudden left him him dead in the water..
Can anyone tell me from experience how this pump mounts? It sits right side up and has its own little gearbox it runs off of, I've read it needs to be timed ad then I've read it's got a key and a master groove on the gear and its dummy proof..
   / Clark Michigan/perkins 6.354 - no start #14
Have you bleed the air @ the injection pump. It has an upper and lower bleed screws on the pump itself. They stick out of the side of the pump horizontally. Think a 5/16 wrench fits em. My old combine with same engine would never crank @ the first of the season without bleeding air out here also.
2008 Ford Ranger Pickup Truck (A51692)
2008 Ford Ranger...
2011 NOV ROLLIGON DOUBLE PUMPER (A53843)
2011 NOV ROLLIGON...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
Ryno Worx Sealant Applicator and sealant pots (A52384)
Ryno Worx Sealant...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A53426)
2013 PETERBILT 386...
