Class 6 Truck
   / Class 6 Truck #31
have to throw my 2 cents in here. Don't worry about what the name is on the front. They are all the same. make the best deal you can on the truck with the best local dealer support. the rest will take care of itself. I have never given a hoot for branding, and I guess it has saved me thousands over the years. As for KW and Pete being better, I don't think so. Can't speak about petes, because its the only brand I have never owned or operated, but Kenworth cabs are nothing special. They never did figure out how to keep their fiberglass from flopping around. And underneath they are exactly the same as the rest. I can't stress enough to get a brand with a good local dealer. Nothing worse than being OS on a busy morning chasing some little sensor that you had to drive the truck(unless you're on a hook) to four or five different shops to get it diagnosed, and then have to wait the rest of the day for a courier to bring the part in from two towns away. You won't care what the name is on the front right about then.
They are basically all the same underneath. It's a brand loyalty thing more than anything.
However, it does make a difference when you have a nicer built cab. I own an IH with a very basic cab. I've spent a lot of money upgrading that cab. If I had a Paccar bros truck, I wouldn't have to do that. Instead, Ihave to live with less creature comforts.
You do pay more up front for a paccar truck and there is a reason that paccar, mack, etc. sell for more as used units than comparable F/L or IH, GMC or Ford. They have higher resale because generally they're more comfortable to operate.
I think the truck the O/P is looking for is a vocational class 6 truck to pull a machine, so unless he wants more comfort, the "basic" trucks should be fine.
   / Class 6 Truck
[ snip... ] I think the truck the O/P is looking for is a vocational class 6 truck to pull a machine, so unless he wants more comfort, the "basic" trucks should be fine.
Yes, correct. I'm just using it to do some local transport (under 150mi) so although creature comfort is great it's not a major consideration.
Also, I was only asking about the air-brakes as a matter of clarification. I'm fine with hydraulic (perhaps even prefer), but I suppose air-brakes would be all the better for getting things stopped (but perhaps overkill for loads under 25K-lbs.). For some reason I thought you had to have a CDL to use air-brakes but I guess I was wrong. And yes, I know I have to have a CDL for the setup I'm going to be using (even though the truck is non-CDL).
Thanks for all the information. I'm still not sure at this point which truck I'll be leaning towards. I think they will all probably work. I'd really like to have a Pete but I don't I'm not sure I could find one in the price range I'm looking at. I only want to spend about 10K (no more than 12K) with no more than about 150,000 miles (maybe 200,000?). Seems like a lot of people are down on the F-650. I was sorry to hear that as in some ways it might be the best truck for what I'm trying to do. On the other hand, I definitely don't want to invest in a piece of junk!
   / Class 6 Truck #33
You're going to be hard pressed finding a good used truck with those specs at that price if it's diesel powered and has a body on it.
You'll probably be into something older.
   / Class 6 Truck
Does anyone have suggestions for truck sales websites. These are the ones I've been looking at:
New and Used Commercial Trucks For Sale | CommercialTruckTrader.com
Used Trucks For Sale at Truck Paper: Freightliner, International Trucks, Kenworth, Peterbilt, Mack trucks, dump trucks, dump trailers, used trailers for sale.
In particular I would like find a used truck coming out of fleet service. I've been shying away from Penske and Ryder fleet trucks. I'm sure their fleet service is fine. However, my guess is that trucks rented by the general public / businesses probably get more abuse than "private" business fleet trucks. That's just my uneducated opinion. If you have an opinion of Penske, Ryder, or other fleet trucks I would like to hear it.
   / Class 6 Truck #36
Ryder service can range from the best to the worst depending on the location. For example, I had a bad driveshaft U-joint that even the person working the fuel pumps would ascertain yet they blew me off at least twice. I was planning on pushing it a bit further then attempt to have it repaired again when I broke down and had to be towed to another location who readily fixed it.
This was on a class 8 long term lease to a company that had more than just a few tractors. I could go on.
I never had any of that with Penske. On a number of occasions, I rented single axle moving trucks for personnal use from Penske and always had excellant equipment with no problems.
   / Class 6 Truck #37
Just be careful on how you are loaded...:D
   / Class 6 Truck #40
Truck Paper, works good if you work the advanced search well, updates a lot. I'ts the big #1 in the used truck world.
Fleets are hit or miss, so are small companies.
Fleets do the required stuff, but the fleet mechanics may or may not be any good. (JB Hunts are no good, let me tell you)
Small trucking companies either do a great job, or are barely getting by and are skimping.
I don't think there are any set fast rules on which to buy and for what.
Except
It's going to have been used hard
It's going to need work.
Just figure on a couple thousand dollars in work on it, no matter what you buy.
Oh, and "fully DOT inspected" means precisely nothing. They are clearly "pencil whip DOT's".
2020 Club Car Onward HP Li ION Electric Cart. (A55758)
2020 Club Car...
2019 Start EV 36V Electric Golf Cart (A55758)
2019 Start EV 36V...
2015 Ford Fusion S Sedan (A54815)
2015 Ford Fusion S...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A54811)
2016 Godwin CD150M...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A55851)
Miller Trailblazer...
2015 Ford F-550 Stellar 7621 7,500LB 3 Ton Crane Service Truck (A55788)
2015 Ford F-550...
