Oil & Fuel Clean oil???
   / Clean oil??? #1
xlr82v2
Platinum Member
Southwestern Illinois
2007 Mahindra 3525, 1952 Ford 8N
OK... this is really strange, or, at least it is to me...
I've got almost 30 hours on my 3525 now, and the engine oil looks to be still just as clean as when it came out of the jug...
I've never seen a diesel do this (or, I should say, NOT do this)... never. I don't know if I should be happy or if I should be really worried :confused:. I'm thinking that oil should be Black by now??
Is this possibly because of the new ULSD fuel? Or, are the Mahindra engines just that tight when they're new? It still smells like a diesel when you start it up... does lowering the sulfur content in the fuel reduce the soot levels by that much too? I wouldn't think that it would, but???
What is your experience with the M&M engines in the M&M built tractors and how long did it take the oil to turn black?
   / Clean oil??? #2
My Yanmar FX335-D has clean oil with over 900 hrs. on it.:eek:
Yes, I change it often (every 50 hrs.:) )
   / Clean oil??? #3
Factory oil? One possibility is the oil isn't holding the soot in suspension like it should. I too have never seen a diesel not turn oil black in short order. Of course if you are looking at it on the dipstick it may be hard to tell, I've seen oil look pretty clean on the dipstick but when drained into a pan it definitely isn't all that clean...
   / Clean oil??? #4
If you are only looking at the oil on the dipstick you may be in for a shock when you drain the oil pan. :D :D :D
   / Clean oil???
Yep, this is the factory oil... I was going to change it at 50 hrs instead of the OM recommended 100 hrs, and then change every 100 hrs after that... Book recommends 200hr change interval.
Yeah, I'm looking at the oil on the dipstick... so I know it might look cleaner than it really is...I've seen that before... but I mean this oil looks CLEAN:confused:
I might just go ahead and change it at 30 hrs instead of 50 with some Rotella 15W-40.
Since these tractors (25 series) are finished and dyno tested at Tomball (or is it Red Bluff, CA or Calhoun, GA?), do they do the initial crankcase/transmission/hydraulic fills there or is that done in India, anybody know?
2005 International 4300 Heil Dump Truck (A50323)
2005 International...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A51039)
Kubota 24in Quick...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A51039)
2018 John Deere...
2009 Yamaha YDRE Electric Cart (A50324)
2009 Yamaha YDRE...
2015 Ford Explorer AWD SUV (A48082)
2015 Ford Explorer...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
