Cleaning PTO coupler
   / Cleaning PTO coupler #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
I have an old New Holland Manure spreader that was sitting outside unused for many years. I have gotten the PTO shaft apart so it will telescope now. A friend of mine used his torch on the PTO locking pin so it moves now. The problem is the splines inside the coupler are just too rusted to get it to slide onto the PTO shaft. Any suggestions on cleaning up the splines or do I need to get a new yoke?
   / Cleaning PTO coupler #2
Try a little WD-40 and wire brush small enough to get inside the coupler. When you think you have brushed long enough, brush a little long. Keep at it. Might make it work.
   / Cleaning PTO coupler #3
Soaking stuff in diesel fuel with a little oil has worked for me.
Might spray with penetrating oil first and you can get some pretty nasty parts to function.
A little phosphoric acid, a small triangle file and small round file and the coupler now fits on the PTO shaft nicely. Now I have to figure out how to put the u-joint back together.
(INOP) 1994 HONDA 200 ATV (A51247)
(INOP) 1994 HONDA...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2009 Jordair Marines-320-DH Trailer Mounted Air Compressor (A51691)
2009 Jordair...
66 Tomahawk Skid Steer Bucket (A52384)
66 Tomahawk Skid...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
