Cleaning skulls
/ Cleaning skulls #1
freedomlives
Platinum Member
Husak, Slovakia, EU
Iseki TS35F, Goldoni Special 140 with powered trailer -- Goldoni Special 128 -- Goldoni Uno for mowing -- Czech Vari system
Our first billy goat died this summer, while I was away actually, so his body was just left by an ant pile for nature to do its thing, and that pretty much left a clean skull, though a bit smelly.
Unfortunately, wolves or wild/stray dogs got to our goats last month and killed a few, including the new billy goat.
I have this friend who likes animals skulls for decoration, so I've promised her those of both billy goats (as well as some other goats/sheep when slaughtering time comes) but does anyone know a good way to get them clean beyond just leaving them outside awhile? Ideally, de-odorized too?
/ Cleaning skulls #3
The only way I've done it is to boil out the skull in a big pot.
You may want to do this outside. Keep the skull entirely submerged in the boiling water.
/ Cleaning skulls #4
Necrophila americana - or Carrion Beetle. They used to use them in the biology lab to clean skulls back in college. Also boiled them clean and would soak in a light bleach solution to help whiten them up when completed.
/ Cleaning skulls #5
I just buried mine for about 6 months. Make sure it is all the way under ground or the mice may chew the horns. Some taxidermists have the beetles for skull only mounts.
/ Cleaning skulls #6
1961 - my second year in Alaska. Worked with a biologist doing a study on the Arctic Shrew. His study needed 25 cleaned shrew skulls. What a real PITA. No problem catching and euthanizing the little beasties. It was NOT so much fun picking the skin and flesh off a skull the size of your little fingernail. We used what are called Micro-tweezers. Then we boiled them. Learned, right off, boiling doesn't take long for a shrew skull.
/ Cleaning skulls #7
We always added a tablespoon or two of Borax to the water while boiling. Just depended on the size of the pot.
After boiling and additional cleaning, a warm water bath with some bleach to whiten the skull.
/ Cleaning skulls #8
If you are going to boil the head, skin it first. Be careful as the skull is very soft and your knife will easily scratch it.
/ Cleaning skulls #9
Have you ever smelled Arctic Shrew soup??
/ Cleaning skulls
Thanks for all the advice. It goes without saying that the heads will be boiled outside-- I have a wife.
The European species of carrion beetle exists in some parts of Slovakia, and I swear I've seen it before, but probably am not going to be able to find it with these temperatures.
/ Cleaning skulls #11
Andrew - I don't know how "rural" you are there. Boiling the head outside is DEFINITELY the way to go. The "smell" would linger inside the house for quite a while. A couple other points. Keep an eye on the operation. While it might not smell so good to us - it could attract unwanted "others". A wandering cat, perhaps a raccoon, a local dog. Something that might want the skull. It might also attract mice or weasels but if you have a pretty good sized pot - there won't be much they can do.
Many will do an operation, like this, in their garage or closed out building. Keeps visitors at bay.
Also - it is entirely possible to over boil a skull. The skull will break down to its component parts. You would have to fit & glue it back together. So check the boiling process often. When everything( all the flesh ) has fallen off or can be easily removed - that's pretty much it.
Then, if you want a bright white skull - as Fossil Farm says - a warm water bath with some bleach.
A final note - dump the water in the pot a good long distance from any of your buildings. No need to attract visitors to any of your close in operations.
If you get a chance - take a couple pictures of the final product and post here on TBN.
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
2022 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2022 KENWORTH T680...
Goodyear 480/80R46 Tire and Wheel set (A65640)
Goodyear 480/80R46...
CASE 850M WT CRAWLER DOZER (A64277)
CASE 850M WT...
4' Barnwood Bar Table (A66408)
4' Barnwood Bar...
New/Unused ATS 13000 Pound Electric Winch (A65583)
New/Unused ATS...
