Oil & Fuel Cleaning tractor motor
   / Cleaning tractor motor #31
Daaaannnnnggg Jay4200, seems like a lot of poison your dumping on the ground all at once?
Oh, you have no idea... :)
You should see me when the dirt shrews come around.
images
JayC
   / Cleaning tractor motor #33
Since you live in Maine, do not make the mistake I did on my first one and let it freeze up at the end of the season. You need to keep it in a warm garage or the basement or it will be trashed the first time the temp drops.
Chris
Good point. Thanks.
Dave.
   / Cleaning tractor motor #34
I would like advice on how I can clean my tractor motor. It's a 1994 Kubota B20 that has never been cleaned and there is a ton of build up on the motor. What is the best way to get 20 years of grease and dirt of the motor without damaging anything?
Mine has closer to 30 years worth. :eek: I don't want all that going into my soil, so This spring I'm putting it on the trailer and hauling it to a car wash which has an engine degreaser option.
Originally Posted by Gary Sweat
"If you have access to an air compressor (it doesn't have to be anything big) you can use one of these. You can adjust the pressure so you don't blow the paint off the engine and it can get into small places. It let you control how much spray you want to use. There are several types of cleaning solution you can get at any parts store. Just stick the small hose into the cleaning solution and hook up the air line. Keeps the mess down considerably."
I'll have to try this first. I can sweep it up afterwards, and it should help those brush piles burn.
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A58375)
UNUSED SDLANCH...
84" Skeleton Grapple Bucket (A55272)
84" Skeleton...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2016 Kubota U55-4 (A57148)
2016 Kubota U55-4...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
