Cleaning under MMM on a B7610
   / Cleaning under MMM on a B7610
nh_bota said:
I just put my tractor on car ramps with the deck all the way up and go at it with the pressure washer or hose. Works perfectly without removing the deck. I've also found that an ice scaper for windshields works perfectly for getting the stubborn areas without damaging the paint (although the pressure washer usually does a fine job).
Yeah, I think I'm going get a set of car ramps, since I don't have a chain hoist.
Do you back up the ramps with the rear tires and go in that way? I was thinking if I backed up and then put my FEL down it would raise the whole thing up.
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2008 PETERBILT 367 FLAT TOP SLEEPER (INOPERABLE) (A55745)
2008 PETERBILT 367...
2007 Ford Expedition EL Limited 4x4 SUV (A53424)
2007 Ford...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
