Clearing Alders
   / Clearing Alders #1
Lloyd_E
South Shore Nova Scotia Canada
2008 Kioti DK 45 sc
I started clearing a couple of acres of alders. There's about 18" of snow on the ground so once the snow is removed I will have to go back and remove the 18" base plus roots.
Seeing what I have for equipment would you:
A/ pull out 18" plus roots with backhoe
B/ pull out 18" plus roots with tractor and logging cable
C/ cut to ground level and bush hog as new stuff grows
D/ pull out 18" plus roots with tractor and box blade
I am reclaiming old pasture. There are a few rocks to remove too. So I am thinking once the alders go I will pass over with box blade to remove rocks and bush hog grass growth for the first part of the summer.
16 years ago I cut some growth in a corner of our pasture and mowed. No growth to date. But this new section has a lot more growth and larger area to rebuild to pasture.
Some of the alders will be used as firewood - 3-4 inches at base and most of the alders will be used to build a woven fence (wattle fence) around a new garden area. What is left will be chipped for mulch.
lloyd
   / Clearing Alders #2
My tractor is not the strongest, so I have to think up of alternates. First thing I do is go after our alders in the spring, when the the ground is still soft and just push them over. Later in the year I am doing C, cut them low. I am not pleased with the results, but my pocket book is cause I am not renting other equipment.
for me I can get the stumps pretty low, if you get too low you kill the blade on your chainsaw. Also this is murder on my back. If you leave the stumps to high you will know it, but for alders, once they are dead the decompose very quickly. I have noticed that after two years a bunch of dead stumps just broke off at the ground when I drove over them. But they sucker, in the worst sort of way. May have to spray them this year to kill them good..
   / Clearing Alders #3
Interesting thread as I'm just becoming aquainted with Alder wood. I have a client who is having some custom cabinets built from Alder and has hired me to build her a fireplace mantle from Alder. She was going to have the top part sheetrocked for a flat screen TV, but then wanted it done in Alder. Finding it has been a challenge. I had some from the cabinet guy, but then she told him I had enough the day after I told him I needed two more pieces, so the job is on hold now until I get that wood.
It cuts good and sands down nicely. I have some scrap pieces in my shop right now that I'm going to work on matching the stain on her floor to the alder, but that's still a mystery to me how it will turn out. I like how the grain isn't very strong, which is why the homeowner chose it. She doesn't like the way oak looks when stained and had hired the cabinet guy to build them before we met. I'm the third contractor she's hired. The first two couldn't figure out how to create a way to run the wires for the flat screen, and I've done a few of these with before.
Here's a picture of the Alder wood.
Eddie
   / Clearing Alders #4
I'm a little confused, are the stumps 18" or 3"-4"?
If they are 18" then I'd say they have to go because after they rot that's going to be a large void for the tractor to hit. If they are only 3-4" just cut them close to the ground (I've got a $100 chainsaw for this type work) and mow over. I dont pull the small ones because it only pulls rocks up.
You will probably want to spray this spring since the rootball will sprout but once it's dead, they shouldn't be a problem.
Eddie, I've got a neighbor that just dropped several 20"+ alders and it's being bucked up into firewood. I thought Alder was getting a pretty good price at the mil (it was!) but apparently the market went the same path as the stock market.:( So if you need more just bring a truck up.;)
   / Clearing Alders #5
If the tree's are only 3"-4" then I would think just wrap a chain and curl them up with the bucket. Or wrap a chain at the base then go over a large tire rim that is next to the tree. Give the chain a pull and see if the whole tree pops out of the ground. If you pop them out of the ground you may want to chop them off a bit so they don't rock over and whack you in the tractor. Alder is a moisture loving tree. Is there a way to cut a ditch to drain away their source of water?
Like others said they rot quickly. Be careful cutting them off at the ground as they can become Punji sticks for people animals and tires.
Sweet Job there Eddie! Alder was a money tree which surprises me. It is great for firewood and smoking Salmon...I hadn't considered it for woodworking..Sounds like you have a tough boss to work for...
   / Clearing Alders #6
Rent an mini excavator.... You can pull hundreds per day, often in one swipe after a little practice, and never have to leave the seat.
   / Clearing Alders
TreeM: The alders are 3-4" thick at base. I started clearing and once the snow(18") melts there will be 18" in height of alders(base) sticking above the ground. So you use the rim as a fulcrum - correct. The pasture or at least this section of acreage abutts a swampy area which I will leave. So yes, a drainage ditch is on the list along with a small pond - very small pond compared to some projects posted on this site : )!!!!!
Also, I found when you open up more pasture you allow more sunlight to come in and dry out the land.
Eddy: I think your alder wood is different from ours. Ours is a bush/tree - lots of sprouts at base and grows to about 15' tall with no real thickness to trunk - 3-4" at most.
LarryD & Woodlands: did the back breaking thing for years. Now that I have the tractor the only bending will be to hook & unhook the chain hopefully....
I will try several of your suggestions. And post some images. We have more snow coming in the next few days...
Lloyd
   / Clearing Alders #8
I don't know anythign about Alder wood. I can't say that I've heard of it before, but the cabinet guy said it's what they are using for all the cabinets on the high end homes that he does. Are there different types of alder trees?
Eddie
   / Clearing Alders #9
More Info - Know Your Woods
I am familiar with Red alder. Did a google to find out about it and found it is part of the birch family. I didn't know that before. It is soft and grows fairly quick here with our damp climate. Splits very nicely and grows reasonably straight.
   / Clearing Alders #10
In the area I grew up as a child the alder trees (Alnus glutinosa) grew in the marshy, swampy areas and often even in standing water. The wood was used for brush handles because it resisted rotting and warpage in water.
The bushy tree might be tree with similar name Elder that is completely different species. It also likes wet area but not necessarily swampy. Some such as Black elder (Sambucus nigra with hollow branches that was brought to America by Scandinavians) have edible blooms and fruits. IKEA sells Elder juice concentate made from the fruit.
   / Clearing Alders #11
Lloyd,
There is a book called "Getting Rid of Alders", Which actually is taken from the pages of,Rural Delivery Magazine.It was printed in 2001. The publisher is Nimbus Publishing.
The title is a bit mis leading however it is full of information and humor,and one chapter is actually about alders. I found it to be a good read,and would recommend it.
If you can't locate it let me know and I will lend you my copy.
   / Clearing Alders #12
They are actually poplar as opposed to alder and when I lived in Maine I hated those things. I once cleared two acres of them by hand with a chainsaw. Whatever the name, we are talking about the same problem.
The easiest and best way is to saw them nearly flush with the ground and leave no sharp point to the stump to injure an animal or tire. Come spring, paint the stumps with a strong concentrate of Roundup and you are good to go. Maybe mix in some brush cutter. Works like a charm.
Some will grow but the cows will eat them. In fact, cattle would solve the problem by eating the growth. If no cows, spray and mow.
Digging up the ground, at least for maybe five years, just made a mess for me. That is, unless you want a lawn. The roots are very long and intertwined and until they rot are a real knot of dirt and runners. That's my story.
Oh, they don't burn well in a pile (bark is waterproof) but that's for another day.
   / Clearing Alders #13
Lloyd,
I prefer to push small trees over with the FEL - it usually pops the rootball right out. Once you cut them, you lose some leverage for pushing them over.
I think it's best to try to get as many roots as possible to reduce resprouting. I'd use the brush hog for smaller stems, and then I'd use the box blade to level-out/fill-in the holes.
If you've already cut the stems, you might think about the following tool:
Brush Grubber HD, Crop, Turf & Nursery Production - GEMPLER'S
Does anyone have any experience with one of these? I've been thinking about getting one, but I'd like to know how well it works first.
- Marty
   / Clearing Alders
oldtrout: Have the book...good read. Especially sitting by a fire made from alder brush!
sixdogs: I prefer not to use any chemicals on the land. And you are correct about not burning well - unless they have dried for about 5 years!!!!
q-saw: I am going to look into that tool. I have a local surplus company that had something similar to the tool - minus the teeth. But if they still have it I can weld some 'teeth' onto it.
Below is a shot of some clearing I did in an adjacent area. The shot shows the type of tree/bush that we call alder.
We are expecting up to 1.5" of rain in the next 24 hours. So hopefully that will beat the snow down and I can do some more cutting this week.
Did a search on google and I think we have the following type of alder:
Smooth Alder(Common Alder)Alnus serrulata, Tree Size: height 6' - 20' : diameter 1" - 4"
Alder burns really hot. In fact blacksmiths who couldn't get coal often turned to dried alder for fuel. So hot, you could get a welding heat no problem. Not wise to burn in your wood stove.
lloyd
   / Clearing Alders #16
The correct name is Speckled Alder, "Alnus Incans"; If I recall from my forestry school days,the leaves are unequal at the base,and are double toothed. I cut about an acre last spring, the customer burnt the brush,and I went back with the hoe on and dug out the stumps,it went fairly fast,than with the pile of stumps he wanted me to build a stump fence,the thumb paid for itself on that job......:)
   / Clearing Alders #17
If you want to justify a new attachment, this is one of the best uses for a 4-n-1 bucket on your FEL.
Open it up, drop it over the 4" diameter x 18" high stump, close it, and you can usually just pull it right out of the ground. If it doesn't come, push forward, pull back and try again.
I would try to leave them 24-30" inches high instead of 18" just to get more leverage in pushing & pulling.
Do this while the ground is still moist in spring and they will pop right out.
   / Clearing Alders #18
I too have speckled alder in a number of places on my property. It seems to attract beaver very nicely:eek::eek:. I push it over with the bucket and drive over it with the brush hog. I am not immediately replanting those areas so I just keep bushogging them for a couple of years and that seems to stop it. If it is really big I wrap a chain around it and pull with the 3ph or chain saw then bush hog. Pile it up for a few months and then fire it up with a propane roofing torch:p -- or buy a book from Lee Valley called Rustic Carpentry and make all kinds of things with it:D
Regards
Steve
   / Clearing Alders #19
we have the red alder out here in the west. The wood is white and can be stained to look like any wood available. It is hard and one of the greatest of woods that can be planed, and shaped without much sanding. If you get it wet though it will discolor and be rotted in two years.
It is the wood used here for smoking salmon also. Grows like weeds and is not uncommon to see them 2ft or more at the stump.
   / Clearing Alders #20
I have read numerous posts on this topic and several threads...
After having tried chains and likeing it, there was little appeal to try the grubbers...
BUT check this one out...
BrushGrubber | Skid Loader Heavy Duty Brush Grubber
Put it on the bucket and open and close from the seat..
now that may be a little better idea..
but many it is $$$$$
whatcha think?
J
2002 Miller Trailblazer 301G Towable Welder Generator (A59228)
2002 Miller...
2010 BOBCAT TOOLCAT 5610 UTILITY WORK MACHINE (A59823)
2010 BOBCAT...
2022 Ford F-150 Ext. Cab Pickup Truck (A59230)
2022 Ford F-150...
PALLET OF(3) CABINETS & (5)BOXES OF CARPET SQUARES (A60432)
PALLET OF(3)...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
