Clearing Brush- What do you use?
   / Clearing Brush- What do you use? #1
Jesse11
The state I call home is on fire. A lot of it is due to uncleared brush. It leads me to ask how do you take care of you brush and with what regularity?
   / Clearing Brush- What do you use? #2
Mostly this.
   / Clearing Brush- What do you use? #3
I use the tractor. Some brush I pull, some I cut, and some I "mow" over with the brush-hog/rotary mower. When I pull or cut brush, my wife like it chipped for use in the garden; most gets chipped, but some gets burned(on permissive burn days).
I have most of my property around the house and granny flat cut back; mostly a spring cut with the roatary mower has it under control.
http://www.fire.ca.gov/communications/downloads/fact_sheets/DefensibleSpaceFlyer.pdf
CAL FIRE - Why 100 Feet?
http://www.fire.ca.gov/cdfbofdb/pdfs/4291finalguidelines2_23_06.pdf
[ame=http://www.youtube.com/watch?v=GPRJeUQByRk]CAL FIRE Inspects for Defensible Space - YouTube[/ame]
   / Clearing Brush- What do you use? #4
2 years ago I purchased a Stihl FS-550 to clean the weeds up between trees. I have quickly found that it works excellent on that nasty brush that covers trees and tries to climb them.
   / Clearing Brush- What do you use? #5
The state I call hoe is on fire. A lot of it is due to uncleared brush. It leads me to ask how do you take care of you brush and with what regularity?
Much depends on the type and size of the brush. I do brushogging, chainsawing, weedwacking mostly annually. If you have a tractor with FEL then check out a ratchet rake. There are many posts at TBN recommending them.
Ratchet Rake, LLC - Tractor attachment, Bucket attachment, Loader, Skid loader, Kubota, Skid steer, Landscape rake, Brush remover, York Rake, Harley Rake, Rock Rake, Tractor rake attachment, Construction attachment, New Holland, Bobcat, Fire safety,
   / Clearing Brush- What do you use? #6
I use the Bush Hog. The fallen limbs and debris that I pick up goes to my neighbor's outside burn stove or my burn pile. On my way from town this morning, crews were doing prescribed burning on the Game Lands areas.
   / Clearing Brush- What do you use? #8
   / Clearing Brush- What do you use? #10
I've had rugged terrain up the canyon sides loaded with poison oak... for me, the ideal solution turned out to be a backpack sprayer with Brush Killer...
I could be 15' away and hit my targets...
A couple of sprayings and the plants died and 5 years later... the brush is gone!
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2017 Autocar Xpeditor T/A Heil V-161 Front Loader Garbage Truck (A59230)
2017 Autocar...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
