clogged fuel filters in 05 Duramax.
   / clogged fuel filters in 05 Duramax. #1
ihookem
Allenton, Wis.
kubota 7510 hst
I filled up on Friday morning at a good truck stop, it was 11 degrees.Drove 430 miles and filled up at the same station Sunday night. It got down to 2 degrees Saturday. On Monday on my way to work it looses power and won't go faster than 20 mph. So I put on a new filter and away I go, till the next day it happens again so another filter, away I go for another day and 100 mi. later I put another filter on and after 30 mi. so far so good. Has anyone had this problem? Is it water or jelling? Also, if it's jelling the filter can I soak the filter in kerosene and use the filter again? thanks in advance to any weird experiences might answer some questions.
   / clogged fuel filters in 05 Duramax. #2
Sounds like you are experiencing gelled fuel. You need to use a fuel anti gell additive. Yes, you can reuse the other troubled fuel filters. You won't need to soak them in Kero, but if that gives you extra confidence...........why not. Once the filters are warmed up the wax will go back into solution. You might want to dump the trouble filters in to a container and check the fuel for water, just as a precaution. I doubt you will find much, but you never know.
Sincerely, Dirt
   / clogged fuel filters in 05 Duramax. #3
Im not sure whether it could be jelling or water freezing and blocking the lines.... Do the old filters look like they have ice on them or does the fuel looking different in the filter holder?
Are you using any sort of conditioner (power service etc)?? Although controversial, I run PS or something similar every time i fill up, and we dont get nearly as cold as WI gets..
Have you drained the water separator lately?
I dont think I would try to reuse the filters, not worth the possibility of the water freezing and tearing the material..
Maybe run a bottle of 911 by Power Service to make sure everything is completely thawed out?? it is suppose to thaw anything frozen
good luck - Let us know how it turns out.
Brian
   / clogged fuel filters in 05 Duramax. #4
Sounds like classic gel. Add a 2x or 3x dose of Howes Diesel Treat and warm the truck up to 60-70F for 24 hours. That will ungel it and then keep it from gelling again. You need to keep adding the Howes at normal rates every fill up. You probably need to switch stations too.
jb
That guy I used Power service white jug and a double dose. John bud I can't get it to 70 and I will put Howse in if I can find it. About switching staions, I filled up there many times and never had a problem with any fuel ever. I called them everytime I needed a new filter and the manager has not called back. I am going to go there and show them the filters and receipts of the filters and the two receipts from therir gas station. I don't know what they will do but a company like BP should care enough to at least give me my money back on the tank. If they don't I guess they are politely calling me a liar. We will see if they ever want my buisness again.
   / clogged fuel filters in 05 Duramax. #6
I had the same experience, but in a boat, and in a lot warmer weather, too. I took on about 100 gallons of diesel full of "algae" from a top rated marina that pumped a lot of fuel. I suspect they got a bad batch from their supplier. I think it took about six filter changes to clean it all out -- after I put some biocide in the tanks.
Definitely get some biocide into your tank.
   / clogged fuel filters in 05 Duramax. #7
The original post suggests that it isn't gelling or icing, since it started happening at a time when the fuel in the tank and lines would have been plenty warmed from excess returned fuel - which is HOT and there is a lot of it.
Fuel circulates many times in 100 miles, water gets separated out as it circulates.
The original poster displayed no knowledge of the water drain, I assume that means there was no attempt to drain water from the water separator.
OTOH there was no mention that the light had come on or that there had been a P1093 (IIRC) code for any of the filter swaps.
So, drain the water separator & check for codes before jumping to conclusions about waxing or icing, or even before swapping filters on speculation that they MIGHT be plugged.
EDIT:
PS If you suspect a part blocked filter but have no CEL try really stomping on it on a steep hill (not when cold).
This will usually demand more fuel than a part blocked filter can allow through, the CEL will light and the code
will be set and stored - as I said, I think it is P1093, BICBW.
:END EDIT
Reg, I unscrewed the bottom of the filter and pushed on the little pump on top. About a half cup of fuel came out. (Is that enough?) I never thought of a code popping up, I never even had a code pop up on this truck in the 77k mi. I've owned it. I really gave it the gas on a flat road and a bunch of black smoke came out. I will drive ten miles or so and and will find a hill and floor it but it has a new filter on it now. I don't know what else it would be except water,ice , jell or dirt. I assume it was cause it got down to 2 degrees two nights before I had this problem so I don't know. I will unplug the bottom every day for 500 mi. or so. I didn't notice any water in the cup that the fuel was drained into. I am heating up one of the filters in the basement with a 40 watt bulb and hope it will melt the jelling if there is any and the water should be gone too. Thanks everyone ,this means a lot to me that you all share experiences you've had. It beats the heck out of a dealer taking two days and who know how much money. This tractor forum has saved me a lot of money doing things myself.
   / clogged fuel filters in 05 Duramax. #9
Sludge formed by organisms that will grow at the interface of the water and fuel in water contaminated diesel tanks, at anyplace in the supply chain. It is commonly, but incorrectly referred to as algae.
Search Google on diesel and algae. Ignore the results concerned with the production of bio-diesel from algae.
Update: I took the first bad fuel filter and put a light bulb next to it overnight to heat it up. Then I put it back on the truck and 70 miles later it is still ok. Must have been ice or jelling. If it was dirt or algae it would still be clogged. I think I could have put a lightbulb next to it overnght without taking it off the truck had I known Just a thought if you ever suspect a jelled up filter. I hope this is the end since I put 10 more gallons in.
   / clogged fuel filters in 05 Duramax. #11
Get yourself some anti gel additive, if it gets down around 2 degree's again you will probably find yourself in the same bad situation. Gelled fuel. It's best to add additive with each fill up thru the coldest months of winter.
Sincerely, Dirt
I called the owner and he swore if I put in isopropel it will suspend the water. He insisted I got water in my tank somehow and was not his fuel. I put it in and have not had a problem in 600 mi. All that problem and only 2 bucks to fix it.Thanks everyone.
   / clogged fuel filters in 05 Duramax. #13
You did know that GM strictly forbids you to add any alcohol to the duramax diesels, right? It will allow the water to get to the injectors and cause damage to them. Additional of alcohol could be grounds for GM to void the injector/fuel system warranty. And yes, they are getting snitty about it with the current financial crisis.
You need to add only a product that will drop the water out of solution so it can be trapped in the fuel filter. That's why it has a drain and a WIF sensor (water in fuel).
   / clogged fuel filters in 05 Duramax. #14
ALCOHOL is not good for any diesels. Check additive bottles to make sure they do not contain alcohol. That is the last thing you want to add to your fuel system.
Sincerely, Dirt
   / clogged fuel filters in 05 Duramax. #15
ihhookem, I had similar problem twice on the same tank of fuel with my 02 Duramax . It's seen -45F without a problem but both problems occurred about 10F in March a few days apart, first with an old filter 3 miles from home, then with the new filter 100 yards from home. I had grabbed a propane torch for warming filter if necessary. Heated the new filter , regained the prime, & drove away. Our snowmobile trail groomer never leaves the shop without a propane torch. I suspected the station where I fuel got a batch of warm weather fuel a little early. Usually if you can get the engine & return fuel warmed up the filter problem will cure it's self. If your problem persists drain the filter into a small container & put in the freezer to see if it's gelling. MikeD74T
I didn't know it was bad for diesels. I won't use it again. It happened today so I put a little in but I won't anymore. I unscrewed the screw on the bottom of the filter and nothing came out. I should have given it a pump but didn't. The little that came out was diesel so I don't know what to think. I hope I didn't ruin the injectors. The funny thing is I ran in the store for 15 min. put in the isopropel, started it up and it was fine. I just don't know what to think.
   / clogged fuel filters in 05 Duramax. #17
Go to Farm Fleet and buy 3-4 of the large jugs of "Howes Diesel Treat" use a triple dose initially, then a double dose then stick with the winter rate. It will protect from water in fuel, gel and help run better with higher cetane rating. I've had much better luck with it than the powerservice junk that has left me on the side of the road.
You unscrewed the water drain and had nothing come out ? Not even diesel? That means you have trapped water that is frozen. Drop the filter tomorrow and put on a new one.
When you added the iso, the water went into solution and was injected. The injectors probably didn't see the humor in the situation.
   / clogged fuel filters in 05 Duramax. #18
I believe on the Duramax fuel filter you have to open the vent at the top of the assembly to drain the filter.That's why nothing came out.Very interesting fuel system.No fuel pump in the tank(except G series vans ).There is a low pressure pump that pulls the fuel through the FICM(fuel injector control module)to cool the module.Then the high pressure part of the pump pressurize the fuel rail with the fuel pressure-injection pressure increasing with the RPM's of the engine-the ECM then reduces the pulse-width of the injectors to compensate for the higher fuel pressure.Probably why I'm happy with my '93 6.5 Chevy diesel pickup.
   / clogged fuel filters in 05 Duramax. #19
No, it will drain.
I opened the drain this morning and pushed the primer, just diesel. I think I will be ok but won't ever put in isopropyl again. This is the firdt time I ever had bad fuel and wont ever buy from that station again.
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
2008 KOBELCO SK210LC EXCAVATOR (A60429)
2008 KOBELCO...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2016 Dodge Journey SUV (A59231)
2016 Dodge Journey...
