audreymir
Here are some methods to unclog the toilet:
Use a Plunger
Get a plunger (either ball-shaped or fold out rubber flange). Make sure that the plunger covers the hole and is submerged in water. It is important to do the push and pull with water. Continue pushing and pulling until it drains.
Drain Snake
The tip of the drain snake screws through the clog and helps to break it up. The snakes are short because most obstructions catch in the first s-bend.
Pull up the toilet and check
If both tools (plunger and snake) failed, then pull out the toilet and have a deep check. The block might be down in the main drainpipes. Call a professional plumber and fix the issue
Use a Plunger
Drain Snake
