Cloudy Pool Water
   / Cloudy Pool Water #11
</font><font color="blue" class="small">( <font color="blue"> I gotta say that my pool is the biggest PITA I've got going now </font> )</font>
I couldn't agree more. I've had an inground pool for 20 years at 2 different homes and not one spring goes by without me threatening to fill it in ... I wish ... the wife loves it. I don't know why. She only uses it a handful of times a year. Still it gives all her relatives grandkids some place to hang out during the summer and they help to keep all the sand and grit on the bottom stirred up. She doesn't appreciate just how much work looking after that thing is, not to mention the expense. Have you noticed how a $1 piece of plastic seems to cost $10 when it's for a pool????? It never fails to amaze me.
Ah, I'm just ranting because I've spent the past week getting it all sparkling and beautiful. When you're working outside, it's nice to walk to one end, dive in, swim to the far end, get out and get back to work. That's about how much time I spend in it.
   / Cloudy Pool Water #12
<font color="blue"> </font> Have you noticed how a $1 piece of plastic seems to cost $10 when it's for a pool????? It never fails to amaze me.
Your right. I just bought a small plastic clip for my polaris ,I thought $2.50 -$3.00. It was $9.95 /forums/images/graemlins/smirk.gif
   / Cloudy Pool Water #13
try using a chemical called Floc
This is good advise. I own a pool service in Austin Tx. Cloudy water is almost always a filtration problem. Flocc is short for flocculant which does exactly what the poster said. You may have to use several applications over a few days to settle all the dirt out. Changing the sand may help if the sand is older than 4 to 6 years. Sand gets contaminated with suntan oils, skin oils and dirt, and it CAN cause channels of unfiltered water to run through it. One thing you can do immediately that can help, and it's cheap, is set your filter to run 24 hours daily until the water is crystal clear. The pool is designed to pump the whole volume of water through the filter in 8 hours. Running it 24 hours a day will filter all the water 3 times. You should see an improvement in clarity every day. If you do it's working and no further action is necessary. If it fails to begin clearing after a couple of days, I would change the sand.
The chemicals can kill the algae very effectively, however they do not remove the algae from the water. That's up to the filter or vacuuming. Good luck!
   / Cloudy Pool Water #14
I've been told that the algae killed by the chemicals was too small to be filtered by a sand filter. The blue stuff called by the brand name " drop out" makes it cling together and drop to the bottom. You have to vacuum to waste and then backwash real good. You have to vacuum real slow so as not to stir the sediment up again..
   / Cloudy Pool Water #15
I know all about Polaris but wait until you have to do some work on the pump and motor. Two or three weeks ago I had to replace the motor because a bearing was screaming. In order to get it off, I had to remove the bolt that runs through the center of the impeller. To cut a long story short, I messed up the head of the left hand threaded bolt so got a replacement when I got the new motor. $14.95 for a left hand bolt. They must have seen this poor old country boy coming. Next time I'll actually look at the price of some of the stuff I buy before I pick it up.
   / Cloudy Pool Water #16
I suspect it's water mold. We had that problem two years ago, every time we would shock it (2 pounds @ 12,000 gallons), the chlorine level would peak, then drop to zero within an hour or two. PH and TA were perfect. Ended up using 5 times the normal amount of HTH powder to get the chlorine into correct range, then used floc to clear it up.
The mold is hard to kill and takes lots of chlorine to beat it.
I usually add chlorine (liquid) to the water in late march to keep the water mold in check.
Had no problems this spring!
   / Cloudy Pool Water #17
The blue stuff you speak of that acts as a flocculant is called polymer. It is basicly sticky stuff that makes the wee little particles stick together until they become big and heavy enough to fall out of the water or be filtered out of the water.
Polymer is cheap and blue. It works real well but the bigger chunks need to be removed after fallout. We use it to treat drinking water and sewage effluent to get the real small stuff to floc out quickly.
   / Cloudy Pool Water #18
</font><font color="blueclass=small">( So...now the water is cloudy, it's blue, but hard to see the bottom. I checked the alkalinity, the chlorine, and the PH. All are right on the money. Any ideas how to clear up the water and what might be causing this? )</font>
I've had this happen before. Don't add any more chemicals if your PH, chlorine and alkalinity are correct and you added algacide along with the other chemicals. Run your filter pump 24/7. Keep the water circulating and it will clear up in a day or two.
Do your weekly maintenance of PH adjuster, chlorine and algacide, run the filter pump 24/7 during the swimming season and you will have clean clear water all summer. Hopefully you have an automatic chlorinator. You can also place a chlorine tab in your skimmers to keep the chlorine level up in the really hot weather.
I think a lot of folks make pool maintenance harder than it needs to be. We want instant gratification and keep adding chemicals until we have a real mess. Sometimes it just takes a couple of days to filter out all the dead critters for the water to get crystal clear.
   / Cloudy Pool Water #19
I use Cutrine Plus in our stock tank (horses) to keep algae, etc. controlled. The nice thing is it's OK for use in drinking water.
2012 Ford F-250 Pickup Truck (A52377)
2012 Ford F-250...
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
2019 KUBOTA SVL95-2S SKID STEER (A52705)
2019 KUBOTA...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A55218)
2-Row Peanut...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
