Bernie,
Good to hear from another 1000 series owner and one very similar to mine in this area, I believe.
Your experience is fascinating relative to my experiences. Some clarification, please about some of what you found in your situation.
You said there was a total lack of lubrication in the PP (pilot bearing?) and TO bearing. Since these are sealed units (at least in my machine!), how did you determine that they were running with no lube?
My sliding hub has a large groove, which I think is a grease reservoir, just forward of the O-ring that seals the aft end of the hub to the aft end of the boss. Mine was well lubricated, although the 'working' grease on the hub-boss interface was pretty stiff; I cleaned that up and put in molly grease. that slides better now.
Also, you say your disk was almost frozen to the tranny shaft. I have really been curious how people manage to tell that since the shaft HAS to come out of the clutch disk in order to disassemble the thing. Perhaps it didn't slide freely on the shaft once you had everything all apart? Mine has always slid freely once I got it apart, but there is no way for me to be sure that it wasn't somehow jammed on the shaft prior to disassembly.
I think I agree with you about the design tolerance being part of the problem. If I ever have to tear this thing down again (and I REALLY suspect I will be in there again!), I think I will take .050 or so off the aft end of the boss to give more room for the hub to move forward. It wouldn't be a problem if the disk wore faster because that would help the lack of adjustment at this end.
Do you feel that your intrinsic problem was the disk hanging up on the tranny shaft? I hope you get another 750 hrs or so out of this clutch job! I have about 900 hrs on my machine; the first clutch job wasn't needed until about 650 or so.
I am convinced I am doing SOMETHING to the clutch plates because of those measurements I made in a previous post. There was one of the old plates that nearly wasn't able to disengage the disk at all. The .4+" that it required is well beyond the travel that the throw-out bearing can have anywhere in its adjustment range.
I do appreciate your perspective on this tractor!
Terry
Terry
