Block the clutch peddle down and let it sit for a week or two. (assuming you don't need it now) It may pop loose on it's own.
If that doesn't work, or you need it now, dog the clutch down and put on your heaviest ground engaging piece of equipment. Bottom plow, middle buster box blade with the scarifiers all the way down and it tipped forward, etc. Start it up in 1st and go at a field for about 15-20 minutes. If it doesn't break free switch to 2nd gear and quickly drop the plow all the way down, plow for 30 seconds, raise it up and dump it down again. This is going to be hard with all the frozen ground, but you get the idea...
You want to put some "shock" load onto the clutch. Getting it all good and hot, lots of vibrations and a variable large load often will get them to pop loose.
If not, try taking out the starter and seeing if you can squirt some WD40 or penetrating oil on the clutch disc. Let that sit for a couple hours then do the plow thing again. DON'T use regular oil. You want something that will evaporate off and not leave you with an oil soaked clutch.
The cause of the sticking is moisture in the clutch housing. There should be a drain. Make sure it is open and dry.
AFter it's free, be sure to clean off the clutch face. Put your plow back in the ground and put the trans in 3rd and feather the clutch to get started. You want to burn off the rust (and any wd40 or similar).
jb
