Clutch Replacement
   / Clutch Replacement #1
llewellynsd
Western Maryland
Sath S-370
Anyone have the best source for Satoh parts around the Mid Atlantic US? I live in Western Maryland and will need to replace I'm guessing the clutch, pressure plate and throw out bearing on my S-370D this Spring. It is starting to make some real strange noises and I've sort of known this has been coming for a while now.
Thanks Shawn
   / Clutch Replacement #2
A few years ago I got parts for my Satoh 650G from:
Darrell Harp Enterprises
P.O. Box 140 819 4th St. NW
Red Bay AL 35582
205-356-4424
Good luck!
   / Clutch Replacement #3
I've got the parts you need to rebuild your clutch. We rebuild the disc and pressure plate and supply a new throw out bearing. This is a lower priced alternative to the high priced new parts. We're located just south of you in Roanoke, Virginia and ship parts all over the U S and Canada. We stock new and used parts for your tractor. Call 800-609-5110 - Bill Rodgers - Valley Power Products.
John Deere 5525 (A60462)
John Deere 5525...
2017 Ford Fusion Sedan (A59231)
2017 Ford Fusion...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56438)
2002 Chevrolet...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
