Clutch/Seal Question
   / Clutch/Seal Question #1
NCMau
NC
MF 202/Ford 8N
MF 202. I posted this thread in another forum but I did not get a response. Sometime in the near future I have to bite the bullet and replace an ailing clutch. At the same time I like to replace the transmission/clutch seal. My question is, can the seal be removed/installed from the clutch or from the transmission side? It would make sense to be on the clutch side, but I just need to hear it.
   / Clutch/Seal Question #2
G'day! :) I understand it has transmission oil leaking into the bellhousing. If there is only a single-stage clutch, it's quite easy.
Does the tractor have a two-stage clutch and live PTO? I recently replaced bearings and seals in a 35 with the aforementioned equipment. It's a little more complicated in that there are two seals, but still quite a straightforward job. If you can let me know, I'll be able to give you some guidance.
Thanks PatrickS2222. Yes it is a dual stage clutch. So both seals are located and accessible in the bell housing, right? Are the seals the same or different from one another? When I check the different vendors, I only saw one seal listed, so I am assuming they are the same.
2017 GENIE S-45 TELESCOPIC BOOM LIFT (A60429)
2017 GENIE S-45...
17307 (A55853)
17307 (A55853)
2010 Deere 318D (A60462)
2010 Deere 318D...
John Deere Z997R (A60462)
John Deere Z997R...
2016 FORD FUSION SS (A60430)
2016 FORD FUSION...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
