Clutch: Wet vs. Dry
   / Clutch: Wet vs. Dry #11
There's no doubt a wet type clutch has advantages...
However, we must all realize dry clutches have been around for decades and have served us well.
As long as the operator can keep his or her foot OFF the clutch (no "riding the clutch"), a dry clutch will last hundreds or even thousands of hours. This includes work that requires heavy clutch usage, such as loader work.
This also requires the operator be smarter then the clutch...
   / Clutch: Wet vs. Dry #12
Would you please explain this. Are you talking synthetic oils or oil additives like STP?
I based this on the fact that every motorcycle and ATV I've ever owned had a wet clutch AND stated in the owners manual to NOT USE Energy Conserving oils. This is because the Energy Conserving oils have a friction modifier that causes slippage in the wet clutch.
I have no other info on it.
   / Clutch: Wet vs. Dry #13
I stole the below statements from here, it explains pretty good:
Using Non-friction Oil with Wet Clutch - ThumperTalk
Very early on, when levels of some oil additives were being lowered, some alternative additives were used as a replacement. One of them at the time was molybdenum disulfide(MoS2). This element is used in gear oils and greases, and at that time also in a couple of new motor oils. This element will indeed cause problems with a wet clutch situation. And it was found out real fast that this was the case.
I think the issue was initially tackled by the Honda folks and the reports of their Goldwing bikes having a massive slippage problem from using the recommended Honda shelf oil. They found out that it was indeed the MoS2 that was the culprit.
Fastforward to today...
It didn't take long for oil makers to realize that another element was needed to replace the slip causing MoS2 additive. The oil makers, and their multi-million dollar tech staffs, realized that using molybdenum diathiocarbamate (MoDTC) was a much better alternative. It was not only oil soluable, unlike it's solid predeccesor, but was proven to not be a problem in the wet clutch situation.
And the wet clutch was only one minute part of the engineers considerations...as MoS2 is a very antagonistic element, which can actually create other unwanted chemicals when mixed with other chemicals and elements. Specifically, MoS2, when in the presence of other chemicals, can create a substance known as sulfuric acid, which is not a good thing in a IC engine that utilizes elastomer seals.
But...it was too late...the myths and legends were already started...
And continue to this day...and mostly passed around by thge less-than-learned, and those wanting to seem as if they have some sort of knowledge in this area.
The truth is about 180degs out of phase with what these folks will tell you. They simply lack credible information...and are backing their warnings up with myth, legend, and hearsay.
Sure, some MC mfgs will state to not use Energy Conserving oils, as they were the ones that would be using alternative elements...and some of these oil makers may simply still be using MoS2...and the bike mfg is simply convering their ***. They are not making a definitive statement by their recommendations. Again, it's just CYA, and nothing more.
Besides, EC (energy conserving) oils do not come in the viscosities that are recommended for use in motorcycles. It shouldn't really even be an issue...but as we see on a daily basis, the issue gets perpetuated by the less-than-learned.
   / Clutch: Wet vs. Dry #14
Very good points... The problem from my point of view is how you use the tractor. While you are very correct in that if you keep your foot off the clutch it will serve a long happy life, in reality the very size and use of these machines make that pratically imposible. It really depends on how you'll use your machine. if you plan on spending hours and hours cultivating potato fields then yeah a dry clutch would be fine. But if loader work and chores are your thing, I'd probably get something with a wet clutch.
   / Clutch: Wet vs. Dry #15
So, please tell me if a mitsubshi 372d tractor is a wet or dry clutch. My father in law got this tractor and dont know much about it. But the clutch is making a grinding sound. We found it in a field and it had been there for like 8 years. please help me, not sure what year we have been told maybe in the early 80's
   / Clutch: Wet vs. Dry #16
Very unlikely that it is a wet clutch TractorData.com Mitsubishi MT372 tractor transmission information if this is it.
Does it grind all the time or only when the clutch is pressed in?
   / Clutch: Wet vs. Dry #17
   / Clutch: Wet vs. Dry #18
If it grinds when you depress the clutch pedal, but not when you let it up, it's probably the throwout bearing. If it only grinds when in gear and moving, it's most likely a transmission bearing.
   / Clutch: Wet vs. Dry #19
Dry clutches last thousands of hours in regular automotive/truck use - daily commuting, towing, etc. Even semi tractors use dry clutches (double disks though). Unless you sit there and slip it constantly, it's going to last a long time. Slipping is what they're designed to do under pressure not high enough to lock them up.
The 5e 3cyl versions use an 11" clutch and it runs about $600 for the drive elements, and another $300 if you wear out the PTO elements. The rest of the expense would be labor to split the tractor.
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2013 International WorkStar 7400 Altec AM650 50ft Material Handling Insulated Bucket Truck (A55852)
2013 International...
Kubota BX2230D (A47384)
Kubota BX2230D...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2015 Chevrolet Malibu Sedan (A55853)
2015 Chevrolet...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
