Clutch
   / Clutch
Kenny, after your post above I got suspicious and checked again and it turns out the rod I was adjusting was the free travel for the left brake pedal. I tried to find an adjustment rod for the clutch and does,nt seem to be one. Clutch pedal appears to operate off a spring located in behind the instrument panel with no adjustment that I can find. Incidentally my tractor is hydraulic shuttle. Thanks for the responses from all who have replied.
   / Clutch #12
Kenny
That's the reason I kept asking which type shuttle shift. The sync-shuttle has a dry clutch and the hyd shuttle utilizes the wet type clutch that the clutch pedal controls a hyd valve not a throw-out brg.
WB Mower (A50120)
WB Mower (A50120)
New Land Honor 5400 LB Ratchet Binder And Chains (A53002)
New Land Honor...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
