Cocked, unlocked, and trigger pressed -- my next tractor is.........
   / Cocked, unlocked, and trigger pressed -- my next tractor is.........
Yes, it is well built and built here in USA! I found one feature Ventrac has done better than previous machines I have owned; the kill switches built into the seat have a delay, thus the engine is not interrupted with every little bump and stretch. I spent a couple of hours yesterday evening in adjusting the contour mower to its highest height (3 1/2"). I typically mow at 3", but wanted some more cushion while I see how this deck gets around on my property. Today I removed and replaced the dual wheel kit so I could check all the lugs and ballast the tires. Added 58# to each of the 8 tires at a nominal cost and the double Schrader valves per wheel made the job a breeze. I found one missing nut and washer on the ROPS and had to move steering cylinder eye to the middle position so the dually tires would not collide. I made a test run on some 30 slope and it did pretty well even though the ground was too soft from the snow and rain we have had. I could tell the hydrostatic transmission really labors the 31.5HP engine, but backing off on the speed lever kept the RPMs up. The forward foot pegs are a good idea, similar to those on my Goldwing.
prs
   / Cocked, unlocked, and trigger pressed -- my next tractor is......... #12
It is best to always keep your hand on the SDLA levers and / or the foot pedal if you have it. This is your only control of speed and braking. When mowing the engine should be at full throttle. The normal mode of operation is to always feather the SDLA levers to keep the engine from bogging down very much. I always try to keep the engine above 3000 rpm, and it makes for smooth operations and good mowing.
Great advice, JackIL. If you think about it, that is pretty much what we do with the gear transmissions too; except we don't have to de-clutch, stop, shift, and re-clutch with the hydostatic machines.
prs
2012 Chevrolet Silverado 1500 LTZ Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
2002 International 4300 Cab and Chassis Truck, VIN # 1HTMMAAP02H548742 (A51572)
2002 International...
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A52576)
LINK BELT LB-98...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A52748)
2020 Massey...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2010 Chevrolet Malibu Passenger Car (A51694)
2010 Chevrolet...
