Chains Cold weather starting a diesel
   / Cold weather starting a diesel
The tractor does have a thermostart with no wire attached. I had the impression that they were not very effective in real cold, but I'd be happy to be wrong about that. :)
   / Cold weather starting a diesel #42
OEM block heaters are a lot less than $75. TSC often gives the illusion of lower prices. Sometimes yes, sometimes not so much.
I never had very good luck with the Thermostart, Rick. I use 15W40 Chevron Delo 400 and even with a fully charged battery my 4610 was hard to start with the Thermostart unit at 20F. It seemed like it didn't turn over very fast. I attribute that to the cold oil viscosity requiring more torque. With a block heater it fires right up on the first rev. Maybe my starter is weak.
   / Cold weather starting a diesel #43
All things being up to snuff, a 4610 should roll right over and start at 20F without any starting aids. It wouldn't hurt to dump the 15W-40 and use 10W-30 in it. If it cranks slower without the block heater than with it, I'd be looking at oil viscosity. Everyone is in love with 15W-40 , but 10W-30 is a better choice till you get up to about 90F ambient.
   / Cold weather starting a diesel #44
how aboout plumbing in a brass peacock to the intake most hardware stores have them thanks
   / Cold weather starting a diesel #45
The INTERNATIONAL farm tractor[dont remember the model]that i plow with at work has a factory either canister for start up.Ijust push a button on the dashand it givesit a shot and away she goes.Ihad never seen this before and have run lots of old iron.
ALAN
   / Cold weather starting a diesel #46
My older JD855 compact has a soft plug block heater.
Would NOT be without one. Even with as much as -20 below all it takes is 1/2 hour plugged in to be toasty warm. But then it also only has 850 hours on it.
I'm sure there is some way to install a tank heater, or lower radiator hose heater.
Good luck
   / Cold weather starting a diesel #47
There is an off the shelf system made by Quick-Start. The system gives you a metered shot of ether so you don't over do it and has a thermostatic lock out so you can't use it once the engine has warmed up. Many of the trucks and loaders I worked on had these systems from the factory and they worked great. Easy to install and maintain. Here is a link to the company Products | Diesel Engine Ether Injection Systems
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
Lockwood 480 Pecan Harvester (A55315)
Lockwood 480 Pecan...
207010 (A55853)
207010 (A55853)
(10) UNUSED SDLANCH 2.5CM X 2 MM RATCHET STRAPS (A57192)
(10) UNUSED...
Hyundai HL 960 Wheel Loader (A56857)
Hyundai HL 960...
https://www.facebook.com/LipoExtremeDropsReviews/
https://www.faceboo...
